ITR Potential buyer
Old Jun 17, 2012 | 06:38 AM
Salvi-EJ1's Avatar
Default ITR Potential buyer
When I go check out a Type R, what are maybe some common problems a Type R might have that I should look for?
Thanks
Old Jun 17, 2012 | 06:49 AM
luvmihatch's Avatar
Default Re: ITR Potential buyer
Way too much VTEC. The frame being twisted is what you need to look for.
But on a serious note.
Every car is different, look for wear and tear stuff. No matter what car I buy I always do a compression test, pop the valve cover off. jack the car up, take a look underneath.
The interior is pretty easy just look it over make sure all the buttons work, every thing lights up, windows go up and down ok.
When I go look at a car I start it up. Make sure the engine is cold from the start. Crank the car up and let it warm up, dont have the radio on, or have any thing going that could cover up certain sounds.
Make sure the car gets up too operating temp and the fan kicks on. When you drive the car make sure u make left and right turns that lock the wheel to the left and right so you can hear if your axels click or pop.
Check out all your gaskets in the engine. if you see an oil leak trace where its coming from. Some common ones are cam seals, valve cover, oil pan etc etc.
Check to make sure the bushings in the suspension are trashed. aka ball joints broken, torn axel boots, worn endlinks etc etc.
When you drive the car make sure you take it through every gear, and red line it a time or too to make sure it doesn't smoke in VTEC.
Make sure all the body panels match up, all the paint is the same color and shade, run a car fax etc etc.
Hope this helps. Just go over the car with a fine tooth comb.
Old Jun 17, 2012 | 10:44 AM
racebum's Avatar
well that just ruled out a lot of itrs on the road
Old Jun 17, 2012 | 02:14 PM
lzylst's Avatar
Would that be from valve stems seals or worn rings? Which more so?
Old Jun 17, 2012 | 03:20 PM
racebum's Avatar
i love how 9 out of 10 people discount valve guides even though they are a big part of why seals start leaking.
as for your question. all the above. the casting process honda used on these blocks doing a hot bore means that some tweaked slightly more than others. you also have a high rpm engine which by nature burns oil.
a healthy type r won't have visible smoke in vtec but there may be a minor puff at crossover.
many burn a quart every 1200-1500 miles and the best seem to do a quart every 3000
the black soot on the rear bumper is often a clue to the level of oil burning. the more worn they become the more of it that accumulates
the engine isn't the be-all end-all of the car though. overall condition, the transmission and general body care are a very big deal.
it's been my experience that the nice, clean, lower mile type Rs will cost a guy 12-15k if you want a really nice example. if you spend 9-10k you're going downhill a bit for a couple grand
Old Jun 17, 2012 | 03:54 PM
j13's Avatar
j13
This thread smells like VTEC.
Old Jun 17, 2012 | 05:08 PM
luvmihatch's Avatar
LOL, right!
You just gotta be care full what you buy. I paid 15k for my R. So I took alot of time bc its a big investment. I did a comp test, leakdown, and I changed the oil and took a sample to have it analyzed (only 25 bucks) Is that a bit much yeah probably but I know my engine is healthy.
Plus it has a Toda head on it, which makes the vtec mmbaaaa that much more.
Old Jun 18, 2012 | 09:58 AM
safedriver's Avatar
Do you want your new (used) Type R to be a garage queen, a daily driver, or a modified track monster?
For a garage queen, look for a 1 or 2 owner car
For a daily driver, consider a 3 to 5 owner car
For a track monster, buy a salvaged car and dump $$$ into it.
Old Jun 18, 2012 | 08:38 PM
Salvi-EJ1's Avatar
Where did you get your oil tested at? I'm gonna look at one this weekend. 2 owner clean Carfax/title. Daily driver.
mikecp
13
Nov 12, 2009 04:31 PM
s2kkid
Honda S2000
Jun 19, 2005 05:48 PM
seeeya04
Apr 1, 2005 09:26 AM
Eyes Only
Feb 12, 2005 09:30 AM
PriMaTe
13
Dec 15, 2004 11:47 PM
