f22a1 not getting spark??
Old Jun 16, 2012 | 06:07 PM
dnxracer's Avatar
Default f22a1 not getting spark??
ok i just swapped a f22a1 obd-1 into my 97 accord i used the dizzy and wiring harness from my f22b2 but got the a1 ecu with a jumper harness and i have all the sensors plugged in it cranks like it wants to start but wont no spark anywhere im gettin voltage to coil but nothing coming out of it i have even tried arcing it out and nothing any ideas guys???
Old Jun 17, 2012 | 07:14 AM
GhostAccord's Avatar
Default Re: f22a1 not getting spark??
Check the resistance on the primary and secondary winding of the coil. Also test the ignitor inside the distributor.
You could also try running the engine with the stock F22B2 ECU. They are both 2.2L F series engines, the P0A should have no problems running it. At least that way you can rule out the ECU and conversion harness as a cause.
Old Jun 17, 2012 | 10:53 AM
jdmcertified909's Avatar
im betting its a coil, igniter, or pick up coil inside the dizzy
big cEe
Mar 30, 2020 10:32 AM
h22accord513
Mar 12, 2010 10:43 AM
AE_Racer
Dec 10, 2007 07:23 PM
fknslmd
Mar 15, 2004 08:34 PM
