1997 integra swap
Old Jun 16, 2012 | 03:56 PM
soon2bdropped's Avatar
Default 1997 integra swap
hello there i have a 97 integra that i picked up with a blown mkotor.. rod went through the block. I have a 94 ls which is obd1.. how do i make this a clean swap. i know the alternator plugs and injectors are different. im not worried about that. im worried about breather for the pcv, vacuum hose and crank sensor connector.. car wont start without the ecu seeing the crank sensor input.ere help me out here. its been a while since i messed around with swaps and integras.
Old Jun 16, 2012 | 05:23 PM
HondaPartsHero's Avatar
Technical Hero
Default Re: 1997 integra swap
If you had the engine wiring harness for the b18 it'll be plug and play.
Old Jun 16, 2012 | 05:30 PM
beecee18's Avatar
swap the oil pump, intake manifold, all sensors, Distributor, injectors, and wiring, basically everything except block and head from your existing OBD2 97 engine onto your newer OBD1 engine.
Koofy23
May 11, 2015 05:14 PM
gotboosthatch
14
Feb 23, 2015 10:00 PM
nels00n
19
Aug 16, 2010 08:04 AM
DelSlowmo
Mar 13, 2010 11:00 AM
rev2ninetyper
Jul 29, 2004 10:37 AM
