94 accord wont start
Old Jun 16, 2012 | 06:35 AM
joshuahettinger's Avatar
Icon6 94 accord wont start
i have a 94 honda accord 5spd that everytime i turn the key i hear a clicking noise coming from behind the radio. so me and my friend took the radio out and tried the key again. on the passenger side of the consule behind the radio is a relay. it was clicking everytime i turned the key. i was wondering what that relay is and if that could be the problem why it is not turning over.
Old Jun 16, 2012 | 07:21 AM
jdmcertified909's Avatar
Default Re: 94 accord wont start
can you take relay out and give us part number?
Old Jun 16, 2012 | 07:43 AM
44x
Old Jun 16, 2012 | 09:36 AM
rc-2201
Old Jun 18, 2012 | 05:11 PM
Lost Again's Avatar
How about this, is the starter turning the engine over?
Old Jun 18, 2012 | 05:24 PM
badb0ybilly's Avatar
Bump. My car is doing the same thing. In my case, the engine is not turning over.
Posted from Honda-tech.com App for Android
Old Jun 18, 2012 | 05:56 PM
MAD_MIKE's Avatar
MM Gruppe B
If the battery is holding a full charge, and the connection to and from the battery are clean and tight. The next thing would be to check the ignition switch. The contacts can wear out causing a no start issue.
Can you make a jumper wire from the battery cable on the starter directly to the solenoid? If the starter easily engages and spins the engine, it is most likely not the culprit.
Old Jun 18, 2012 | 06:24 PM
If the ignition switch is bad, the car should start by jumping the starter right?
Old Jun 18, 2012 | 06:28 PM
MAD_MIKE's Avatar
MM Gruppe B
If when it is turned to ON and the ON conctact is fine, if you jump the starter with the car turned to ON then yes it will start.
If you just jump the starter with the car OFF the starter should just spin the engine.
Old Jun 26, 2012 | 09:47 AM
well guys my battery was dead and the firing order was messed up
1337knub
Feb 10, 2014 06:57 AM
wizzbangca
Nov 17, 2013 07:11 AM
hondakevin21
Jan 25, 2007 06:12 PM
chubbz
Dec 19, 2005 03:39 AM
Grnade
May 11, 2005 11:50 PM
