94 teg RS, 10pt cage, lots of extras, golden eagle, skunk2, victor x
1994 Integra RS. 10pt cage, buddy club pro suspension, Enkeis with new tires, full wire tuck including hand made engine harness with firewall 37 pin connector. has full clean interior. it is missing the climate control and heater box. Obivously i was setting it up to be a drag car. Ask for details...runs and drive with the stock LS, doesnt burn oil and tranny shifts perfect. $4500 Does need a windshield as it was cracked during cage install
Golden eagle sleeved 84mm, wiseco 9.1, eagle rods. Balanced to 10k by kevin at precisin and assembled by Don at Oneils, Nvere been fired and is still in the bag. Comes with brand new OBD2 oil pump, rear main cover and seal and all the gaskets. $2500
B16 head with supertech dual springs, new guides, and seals and slightly used OEM new valves, resurfaced, stock ports - $650 comes with valve cover
Comp twin disc, used one dyno session is in excellent shapt, $700
Skunk2 pro 1 cams - $550
Victor X (b16-typeR) powder coated black - $250
Foreward facing divided b series turbo manifold, will need a wastegate flange, sch40 stainless - $600
Lots of little things...everything HONDA must go!
TEXT IS BEST 509-496-8108 no lowballers and no trades!
Pony_Fed95
Mar 15, 2010 08:35 AM
