ek coupe LSV - running rich, oil leak, high idle, and bad VTEC wiring
Old Jun 15, 2012 | 09:27 PM
Lou845's Avatar
Default ek coupe LSV - running rich, oil leak, high idle, and bad VTEC wiring
so i had traded my bagged sedan for a 98 ex coupe with a built lsv, there are a few issues that i was aware of before trading, but any way themotor has flat valves
brian crower stage 2 dual valve springs
brian crower titanium retainers
brian crower stage 2 cams
skunk 2 intake manifold
msd ignition
255 pump
h22 injectors (310cc)
b18a1 block
golden eagle sandwich plate
block guard
eagle rods
forged pistons
acl race bearings
light weight pulley
arp head studs, rods, mains, and flywheel bolts
b16 tranny with stage 5 clutch
short shifter
light weight flywheel
greddy timing belt
hasport mounts
type r replica 4 to 1 headers
high flow cat
full skunk 2 exhaust.
runs kind of rich and is on a p72 ecu, the issues are theres oil leaking from the dizzy, the vtec solenoid ran to the horn, idk why. after getting on it itll stay at 2k rpms but when i turn it off then on its at normal idle but during the time of high idle it grinds gears.i drive the car without hitting vtec is that gonna be an issue for a short period of time ? also how can i properly wire vtec and what ecu is best ? any help would be appreciated
Old Jun 15, 2012 | 09:36 PM
doood's Avatar
been there done that
Default Re: ek coupe LSV help
vtec ran to the horn? wtf? so when you hit the horn it hits vtec?
Old Jun 15, 2012 | 11:57 PM
4DoorCivic1's Avatar
lmao!!!!!!
Old Jun 16, 2012 | 12:03 AM
first off, do you know the guy?
are you sure those parts are really in the engine?
either way there are threads/post on how to wire up vtec properly and that ecu is it obd1 w/ jumper harness or obd2? figure it out and tune it before it blows up on you........just my opinion
Old Jun 16, 2012 | 12:17 AM
Dc4LsTeG's Avatar
EK9
Or does the horn go off when you hit vtec
Old Jun 16, 2012 | 04:31 AM
92lxsleeper's Avatar
is this how Johnny Tran activated vtec in his s2000? lol
Originally Posted by JohnnyTran
too soon junior
Old Jun 16, 2012 | 11:23 AM
Former User's Avatar
Default Re: ek coupe LSV - running rich, oil leak, high idle, and bad VTEC wiring
Thread titles MUST summarize the tech problem so that members browsing titles can easily understand the problem without reading the post -- Title edited.
Old Jun 16, 2012 | 03:20 PM
Lou845's Avatar
I couldn't tell you why it was ran to the horn, apparently with the ecu it's running it doesn't hit v ? I dont even wanna ask the kid why or what made him wanna do something so..... Wrong lol, would it be ok to run it without hitting vtec ? Also thank you for the title edit.
Old Jun 16, 2012 | 10:57 PM
jbpnoman's Avatar
Running the car without vtec will not damage anything.
Old Jun 17, 2012 | 07:18 AM
Lou845's Avatar
can any one tell me why the idle stays at 2k after driving it for a little while ? after i turn the car off then back on it settles back to normal idle, but while its at high idle its grinds gears as well and i no its not my shifiting causing it. i just wanna make sure nothing goes wrong
Old Jun 19, 2012 | 07:42 PM
Lou845's Avatar
no one ? also a few more issues. the top of the tranny is covered with oil could that be because of distributor ? i cant see any other visible leaks. when motor is at idle it makes a knocking noise and looks like timing belt is slapping around but doesnt rise with idle, and timing belt is tight when the car is off. speedo is stuck at 20mph when driving, driver side mount is welded to the car, oil looks a little watered down but not milky, coolant is greenish brown, and im regretting this trade terribly, but having hopes of being able to correct the issues being that there minor since the car runs strong. please help me out here
Old Jun 19, 2012 | 07:52 PM
gwarfare's Avatar
u ready for this,bad wiring plus blown headgasket,rod knock,possible rings are gone. Needs to be rebulit.
ImPuLsIvE
Sep 25, 2006 11:02 AM
Spo0NFed E M 1
16
Jun 14, 2006 01:07 PM
raysjdmh22a
Oct 19, 2005 08:09 PM
AznBlueBoy
May 19, 2004 08:30 AM
DsITR
Sep 23, 2002 07:36 AM
