over heating honda civic 1997 auto
after 3 to hours of on and off driving my car starts overheating,tail pipe in water hose bottle produces gas and water inside bottle disappears and fan for cooling some time works sometimes not,when water insdie bottle vanishes(sometimes not)the heating indicator goes up showing over heat
generally there is no leakage outside from radiator or bottle
what is the problem,which thing is better to replace or change to avoid heating???
will somebody suggest me about this thing??what is the rectifying procedure???
Classic old honda.
Probably a head gasket or a crack in the block or head.
Usually cheaper to replace engine with a similar running engine.
OR
To replace the head gasket you need to check the head for warpage.
Mill the head replace timing belt, water pump, engine seals, cam seals, etc.
Money starts to add up going the rebuild route. To do it right.
OR
Time to upgrade to a swap & in your case convert to manual.
OR
Sell it as is and move on.
OR
OR
OR
only my engine heats and water boils in radiator and than convert into steam,after that the temperature gauge rises
Classic old honda.
OR
OR
OR
OR
OR
OR
BUT
1- I WANT THIS CAR TO RUN ATLEAST 2 MONTHS ,AFTER THAT I WILL REPLACE THIS ONE WITH NEW CAR,for time being i want this car to run properly without over heating
i have some clues about overheating problems
1-my car sometimes remain in 2nd gear do not go to 3rd or 4th gear that causes engine to use more power and in result it overheats engine
engine overheats boils water and water become steam and than temperature gauge rises
I HAVE ONE SOLUTING IDEA CAN SOMEBODY AGREE WITH ME???IS THAT WORKS???(keep in mind i want to run this car for only 2 months)
i put cooling fan on running mode all the time by removing auto on /off switch.that means engine on fan on,it makes my engine to produce less heat to boil water,is that works????
what is your opinion???
1 solution that comes in my mind is that i put cooling fan on running mode by removing on/off switch it means engine on fan on,it drops temperature of water and water remain cool and do not boil??
is that works???is that idea good for only two months as i have plan to replace new car with this
please tell me about this idea is that work or not???
You can run the fan but that is not a fix.
Man it can a lot of things, a clogged radiator, bad water pump.
I would replace the thermostat first and see how it is.
The worst case is the headgasket is shot.
okay this is gonna take 2 people..
1.pop the radiator cap.
2.have someone start the car with you watching the open radiator.
3.if coolent shoots out of the open radiator cap then u know your head gasket is blown..
u say coolent turns to steam? no u r prob loseing coolent in the cylenders cuz u have a blown head gasket.......dude take your car to a mechanic.....
Did you actually do the test, or are you just assuming the test is for external leakage? I'm guessing you didn't do the test. If you had, we'd be able to tell you exactly what the problem is by now.
can you tell me what is the function of cooling fan ,if it tuned on most of the time than waht happens????is thet fan cools the water and stop making steam???if i use cooling fan switch on most of the time???
yes i have done head gasket test,opened the radiator cap and started car no water ejected in an instant,probably i wathced for 2 mints ,no pop up water
Click on this link and do what is described and stop being dense.
** How To - Leakdown Test ** - Honda-Tech
And you better not be running straight water.
Good mechanic is very hard to find in my area,no one able to give me clue of problem.every mecahnic has different stories
After 2 hours of on and off driving Why water in radiator and bottle get warms and than boil than it converts into gas,than there is no water inside radiator,the leak test is ok,gasket has no problem than what???
how can i stop water to boil in bottle or radiator??
and
what is the function of cooling fan????
and
kadavis90
Sep 8, 2017 11:40 AM
azciviclx98
13
Feb 21, 2012 07:27 PM
Pancho2193
14
Jun 15, 2011 02:03 PM
