Has anyone ever tried the t6 Borg Warner s475?
Old Jun 15, 2012 | 04:15 PM
dantamparacer's Avatar
Default Has anyone ever tried the t6 Borg Warner s475?
I found this turbo at a very reasonable price and I am wondering if anyone has ever tried this. It has a 75mm exhaust side and a 96mm turbine with 1.32ar housing. I am not worried about conforming to class regulations as I will not race in events. I am wondering if it will work. I have a 2 liter ge sleeved block with turbo tuffs so it should be good for a lot of power, I guess the real question is can I spool it?
Old Jun 15, 2012 | 07:32 PM
92redhatch's Avatar
Default Re: Has anyone ever tried the t6 Borg Warner s475?
Until tony or miller do it nobody will have the ***** to do it. I think it might work if you have a motor that will rev high enough to keep it in the power band. It most likely wont be the best turbo for your setup. That would be a good username btw t6honda
Old Jun 15, 2012 | 08:33 PM
BlakeJ53's Avatar
Give it a shot let us know how it turns out!
Old Jun 15, 2012 | 11:21 PM
.adam.'s Avatar
75mm exhaust side with a 96mm turbine eh? good luck
Old Jun 16, 2012 | 08:37 AM
dturbocivic's Avatar
turbo tuff = holes in your block
Old Jun 16, 2012 | 10:15 AM
Ok if the turbo tuffs are so bad what do you use?
Old Jun 16, 2012 | 10:32 PM
tagperformance's Avatar
poor tuning, lack of lubrication = holes in your block
Fixed.
sevenj
Feb 24, 2009 05:58 AM
street_ride14
Jun 21, 2008 09:27 PM
Big_S
Feb 6, 2007 08:17 PM
Rabid Machina
Mar 31, 2004 10:45 PM
wu tang
Dec 29, 2001 04:17 PM
