What to look for in a used EK civic
Old Jun 15, 2012 | 03:16 PM
bk7794's Avatar
Default What to look for in a used EK civic
I am looking to upgrade from an EF civic sedan to either a Hatch or a coupe version of a 96-00 civic DX. Was there any problem areas that I should look for on these civics other then obvious? Was there any recalls that I need to concern myself with? Thanks.
Old Jun 15, 2012 | 03:32 PM
CO671's Avatar
Default Re: What to look for in a used EK civic
http://www.samarins.com/check/engine.html (from: https://honda-tech.com/forums/honda-civic-del-sol-1992-2000-1/faqs-frequently-asked-tech-questions-1998336/)
https://honda-tech.com/forums/honda-civic-del-sol-1992-2000-1/car-tips-buying-used-civic-3055042/
Old Jun 15, 2012 | 04:00 PM
bk7794's Avatar
Cool, thanks. I will have to make a checklist so I remember everything I need to check. I forgot about checking under the oil cap for my first attempt.
I know I have watched Davidsfarm's video on buying a used car.
Also the first one I started had an extreme knock to it, but it sounded more like loose valves because I get the same thing and when the oil warms up it goes away.
Old Jun 15, 2012 | 05:36 PM
mikekh10a's Avatar
so why exactly are you aiming for a DX?
Old Jun 15, 2012 | 05:51 PM
jbpnoman's Avatar
EJ6, not EK.
Old Jun 15, 2012 | 06:37 PM
DumpedSi's Avatar
theres not a lot of tel tel problems with these cars. Just make sure it runs good and go over the body panels to make sure all the vins are intact, this will prove if its been wrecked or not
Old Jun 15, 2012 | 06:49 PM
grumblemarc's Avatar
The Grumpiest
With all due respect there are TONS of issues to be found with these cars. The cancer is one. Hacked up wiring is another. Unless you are good with electrical avoid these at all costs. Bushings are on their last legs. Look out for those. Headgaskets are epidemic for failing with the age of these cars. Lots of overheating issues. Make sure the cooling system is in working order. Have the engine compression tested at the minimum. Heavily molested wiring on the interior. Check for smoking and/or erratic idling. Dirty engine bays will give you a clue that the car has been neglected. Cheap knock off parts installed on these cars. In particular, Ebay suspension.
Old Jun 15, 2012 | 07:11 PM
98civdx's Avatar
Master Detailer
If the car isn't all stock, with reccords, be suspect.
A lot of Honda's get modifyed with low quality parts, half *** install, etc.
While sitting on CL looking for a cheap DD for my buddy, I counted 5 cars with Ebay suspension parts, and 1 with "good" quality parts. It's ****ing sad.
Old Jun 16, 2012 | 08:38 PM
alex eg hatch's Avatar
Great point !!
Old Jun 16, 2012 | 11:48 PM
nalo_b's Avatar
Heard that the stock headers crack after 100,000 something miles. Check for exhaust leaks at the header. Just bought an ek couple of days later went to check the header gasket took of the heat shield and the header was cracked down the center. By the o2 sensor. Read later that many people have encountered that.
Old Jun 17, 2012 | 09:04 AM
Pedro TT's Avatar
After just recently purchasing an EK, I can attest to this problem. Listen closely for an exhaust leak. Also, watch out for rust underneath the rear hatch hinges. That body seam always seems to be a problem.
Another problem area is the heater. There seems to be a plastic piece in the HVAC controls that always breaks preventing proper activation of the heater. Every single EK that I looked at had this problem.
SoCAL S2
Nov 25, 2011 06:38 PM
c1_sleeper
Jun 11, 2008 04:45 PM
craftysince86
Sep 22, 2006 12:57 PM
craftysince86
Sep 8, 2006 02:42 PM
Downey
24
May 24, 2002 08:27 AM
