Lsv turbo build help
Wassup honda tech im new to this site , im a 17 yearold kid whos loves honda n now working on my first build i got a 92 dx hatch .. The setup im working on is lsv turbo but im having trouble on wat to buy . Im looking to make around 300- 400 hp iknow that alot for my first build but idont care i have about 2500 to spend on it so help me out wit wat pistons, rods to use and if needed what sleeves to use . im want to use a t3t4 turbo kit since it my first but dont know wheres the best place to buy it at . . I got a gsr head thinkin of buying skunk2 pro 2 cams edlebrock victor x intake mani but dont know wat else to buy as far as injectors, tb , fuel rail, cam gears etc.also i wanna kno whats the best tranny to use i was thinking the 98 spec type r lsd trsnny wit the 4.7 final drive but again idk So please help me out on what i should buy to make the power i want thanks honda tech -jeff
Slow down there chief. you first need to learn what it takes to run LS/VTEC, THEN you need to know turbocharging. All these parts you're spouting off contradict exactly what you're trying to do here, which means you need to slow your roll, hit the brakes and start researching what it needs to do both (Skunk2 Pro2 Cams on a Turbo car...ummm HELL NO). $2500 isn't going to cut it to do both, so perhaps understanding that first will get you to check out some research on the site.
First, look about LS/VTEC, and how one puts one together (it may not be necessary depending upon what you're trying to do to your car here.
http://marketplace.honda-tech.com/sh....php?t=1676914
then you need to read these little Frequently Asked Questions at the top of the Forced Induction forums.
http://marketplace.honda-tech.com/sh....php?t=1024174
These are living documents, so there's always going to be updates. Put your checkbook down, and start reading for about a week or so (seriously). Then we can help further. k? There's no point in making further suggestions if you don't even know the basics of turbocharging (so guys don't give ideas of "piecing together" anything because the OP needs to know the basics first.)
Good luck, and let us know if you need more referral articles to research so you can make some intelligentdecision-making.
Discosteak
Nov 9, 2010 09:31 PM
