Swapped LS Shell With Vtec Swap-vtec not working
Old Jun 14, 2012 | 07:00 PM
GHOST2049's Avatar
Default Swapped LS Shell With Vtec Swap-vtec not working
I recently did a swap on my 01 integra ls model , i swap my old 96 gsr swap, i used the vtec engine harness from the 96 , i just plugged in a (obd2b to obd1)gsr computer, do i have to run the vtec to the ecu? or is there another reason vtec is not working
Old Jun 14, 2012 | 07:05 PM
Civic2Fast's Avatar
Default Re: Swapped LS Shell With Vtec Swap-vtec not working
if you swapped into an ls and didn't also swap the body harness to the ecu then yes you'll have to run wires for vtec pressure switch and solenoid... and if you're running a gsr ecu then you should be throwing cel's when vtec fails to engage
Old Jun 14, 2012 | 10:59 PM
Solster's Avatar
Unless the "optional" CEL bulb was removed for Wight reduction.
Old Jun 15, 2012 | 12:27 AM
GHOST2049's Avatar
i didnt change the body harness, and i have cel already ( o2 sensor) ,
thanks for a reply
Old Jun 15, 2012 | 01:13 AM
HondaPartsHero's Avatar
Technical Hero
Then you'll have to wire VTEC, knock, and the IABs directly. What 02 code is it? This will also affect VTEC activation.
Old Jun 15, 2012 | 01:54 AM
Solster's Avatar
Yes if you have a CEL Vtec is gone
according to what i have seen of the If/Then file (Standard computer code for making changes) when the ECU turns on the CEL the first things to go in a OBD1 P72 is the Vtec, IAB's timing and injector pulse width. it also switches over to a Predefined fuel and timing map set.(it's a +/- value to the base numbers of the rom) witch is why a P28 can still run a b20 in limp mode.
Old Jun 15, 2012 | 02:51 AM
Mr Envy's Avatar
id fix the cause of the code, run the wires/ swap loom and go from there but keen to hear what it is
Old Jun 15, 2012 | 06:33 AM
A L I A S's Avatar
you need to wire in wires for vtec solenoid, pressure switch, knock sensor, and a ground for the solenoid....go on google it'll take you 5 mins to figure out how to do
Old Jun 15, 2012 | 11:24 AM
GHOST2049's Avatar
o2 down stream sensor, only code i get, after i change my head ima wire everything ,
Thanks honda tech
ungers_21
Jun 16, 2008 05:02 PM
B16'D DA9
May 25, 2005 05:17 AM
nh4442
Apr 25, 2005 11:36 PM
soquickls
Jun 28, 2004 05:52 PM
