no power to condensor/compresor. need help troubleshooting
Old Jun 14, 2012 | 11:59 AM
4potnick's Avatar
Default no power to condensor/compresor. need help troubleshooting
having problems with the a/c system in my civic. 93 cx converted to r134a(94 complete a/c system, new compressor, dryer, and expansion valve). 1st compressor did not work and I believe it fried some things. cant get the a/c to work without jumping it. tried different relays, checked fuses, and checked low pressure switch(which does have power, jumped it to no avail). not a electrial genius but have been toying/swapping/working hondeas for about 12yrs so I have a little knowledge. just need some help troubleshooting.
Old Jun 14, 2012 | 12:38 PM
Former User's Avatar
Default Re: no power to condensor/compresor. need help troubleshooting
Still using the stock 93 Civic A/C system wire harness? Have you tried jumping the thermostat/thermoswitch in the evaporator? Does it have voltage?
Old Jun 14, 2012 | 07:46 PM
4potnick's Avatar
Im still running my 93wiring. Are you talking about the 2 wire sensor going into the evap. Ill check it in the morning. Test then jump
Old Jun 14, 2012 | 08:38 PM
What are you jumping to make the A/C work?
Old Jun 15, 2012 | 05:20 AM
4potnick's Avatar
Straight 12v. Switched
Old Jun 15, 2012 | 05:26 AM
Straight 12v.
What wire or wire terminal? The Yel/Wht or Blu/Red wire? If you jump the unplugged connector for the thermostat, does the A/C work?
Switched
Not sure what you mean.
Old Aug 14, 2012 | 07:57 PM
4potnick's Avatar
Late reply, problem was a/c switch. Located in dash piece.
bigchris2000
Jul 3, 2010 08:35 PM
.Mason
Oct 15, 2008 08:02 PM
dc2teg2006
Jun 19, 2008 10:40 PM
kin413
May 30, 2007 01:54 PM
Redwidow
Dec 2, 2006 11:06 AM
