erratic idle?? need help. just finished putting in rear disk breaks in my rex.
Old Oct 14, 2002 | 12:57 PM
Jasper's Avatar
Default erratic idle?? need help. just finished putting in rear disk breaks in my rex.
I just finished my rear disk conversion on my rex. Everything came out of a 93 Integra. I swapped out the trailing arms, booster, and M/C.
I tested the booster and it works fine no leaks. I double checked all the hoses and no leaks there. I'm running a DOHC Non-vtec B-series motor. has anyone had this problem before... If so, what fixed it.
FYI: it only idles erratic when the car it cold once it warms up its alright
Thanx
Jasp..
[Modified by Jasper, 9:58 PM 10/14/2002]
Old Oct 14, 2002 | 05:19 PM
kinesistech's Avatar
Default Re: erratic idle?? need help. just finished putting in rear disk breaks in my rex. (Jasper)
There are 2 vaccum diaphrams in a brake booster. They can leak air from the inside too. Its related to the booster or the vaccum line and chack valve to the engine. Does the check valve work still?
jceron64
May 28, 2011 07:32 PM
B16A CRX
May 6, 2009 04:17 PM
beho
May 12, 2006 02:59 AM
EGhatched
10
Mar 31, 2004 08:45 AM
Jasper
Oct 15, 2002 06:09 AM
