Transmission & Drivetrain Gearboxes, Differentials, Clutches
Stock b16 tranny hold up?
Old Jun 14, 2012 | 06:44 AM
EJ8Squad919's Avatar
Default Stock b16 tranny hold up?
Im finishing up my build put my motor all back together last night and put the motor n trans back in the car. I have a ej8 with ls vtec going to make around 450whp. I have a stock s4c tranny with the stock b16 open diff. Im not going to track the car or launch it or anything. Im just using this tranny so i can buy a gsr n build that one on the side. I just want to know will the b16 tranny hold up? Heard they are fragile. Also heard that i will be fine as long as i dont slam the gears too much. How much hp can a stock b16 tranny hold?
Old Jun 14, 2012 | 07:23 AM
Aquafina's Avatar
Default Re: Stock b16 tranny hold up?
You should be ok if you take it easy. Same strength as a GSR or any other 92+ B trans more or less.
Old Jun 14, 2012 | 08:36 AM
Ok thanks. How will the b16 be with a quaife lsd? Or go with a gsr with a quaife lsd. Its a street car
Old Jun 14, 2012 | 10:21 AM
Gearspeed-Performance's Avatar
GSR is a good middle of the road trans that works well with Boosted cars. A good rebuild with a reputable LSD will suit you find for your power range and plans for the car.
Old Jun 14, 2012 | 11:04 AM
Dark_Teg's Avatar
I had Synchrotech build up my B16S1 tranny with carbon synchro's, Quaife LSD, and LS 5th gear and love it!!
Old Jun 14, 2012 | 02:08 PM
For my S4C what is the best tranny fluid? I read up n heard good stuff on amsoil synthetic gear lube 75w-90? Is that the best stuff? Its still stock open diff
Old Jun 15, 2012 | 05:44 AM
Dark_Teg's Avatar
Honda MTF
Old Jun 15, 2012 | 07:13 AM
I heard honda mtf sucks and isnt that great
Old Jun 15, 2012 | 08:25 AM
Aquafina's Avatar
You heard correct. I like Torco MTF and RTF. RTF for boosted applications.
Old Jun 15, 2012 | 10:23 AM
RTF? Whats the best for my application boosted ls vtec aiming around 400-450whp
Old Jun 15, 2012 | 01:29 PM
lsturbo33's Avatar
Amsoil syncromesh is what I use.
Old Jun 18, 2012 | 11:38 AM
Aquafina's Avatar
Boosted I would use the RTF.
blu00Si
Oct 11, 2013 05:15 AM
SLIM NOTHING
30
Jan 25, 2011 11:42 AM
TurboCivic11
Dec 22, 2009 05:51 PM
JRSC•GSR•EG
17
May 8, 2009 10:13 PM
crashzerothree
Feb 19, 2007 04:13 PM
