90~91 integra distributor won't bolt on to 1st gen b16?
I was told by someone here that 90~91 integra distributor can be bolt onto the 1st gen b16..however, i found out the the two plugs won't connect (different wiring). anybody know how to solve this problem?
Jeff-
Jeff-
Unpin the wires from the old distribitor and and unpin the one from the integ and pin it into the b16a one.. match up the wires.. obd- obd is the same color code.
i tried to do that..but the problem is that b16 distributor have 1 extra wire than integra one...what should i do w/ that?
Jeff-
Jeff-
thas weird cause mine pluged right in.....just the bolt holes don't all line up to the head...but i fixed that too....just took the guts out and put em into my b16 distributer....
hmm..that's weird cuz mine doesn't fit and outter pattern is exactly the same. just the plugs aren't same
Jeff-
Jeff-
yeah i got mine right from acura...(at a heathy $450)....but it pluged right in.....i've been using th esame dizzy for almost 2 years with no problems/cel's
i got a b16 distributor that works perfect
110 ship'd wherever, just needs a cap (can be bought from autozone 90-91 integra distributor cap works perfect, costs 10 bux)
so you have it bolted to the head but the plugs dont match?
what wiring harness are yo using?
Need all the help I can!!!!
Jeff-
what is the engine wiring harness from?
Jeff-
why dont you just get a 1st gen vtec dizzy...I bought mine here on HT for $150 plus shipping. But thats really odd that you have an extra wire.
because i need something to get my car to run. I don't know why either..so I'm going to take a picture and see if you guys can figure that out.
and uh...people are selling it for $110 shipped here.
Jeff-
Jeff-
here are some pics of the plugs..
This is the plugs off the car
Front view of the plug
The original distributor
The 7 wires i'm talking about
The new integra distributor (so the junkyard shop told me)
Back view. Only 5 wires (or 6)
So did they junkyard shop gave me the wrong distributor? or I'm just lucky to get something that wasn't for my car? help..anybody?
Jeff-
[Modified by Corporal-Jeff, 8:03 PM 10/15/2002]
Jeff-
This ain't a 90-91 Teg distributor!!!!
100% shure.
I've got one on the bench.They have the same round plug.
I dunno which one you got....
100% shure.
That's an 88-89 integra distributor at the bottom, not 90-91. Even if you wired it up it would not work right. It's missing a sensor (the one that is normally on the exhaust cam in 88-89 integra/ZC), and hence is missing 2 pins on the connector (5 vs 7)
gringo7718
May 6, 2009 09:00 PM
MAUCH3
Feb 5, 2004 07:25 PM
