Transmission & Drivetrain Gearboxes, Differentials, Clutches
Need advice for a turbo automatic d series
Old Jun 13, 2012 | 09:55 AM
Stevoyayaya3's Avatar
Default Need advice for a turbo automatic d series
Ok ive searched and searched and only came up with a few results. Thats expected since its an auto, but im planning on turboing my girls sedan. I have the kit already. Its auto with a/c and a mini me swap. i only wanna run 6-10pds of boost. My question is will the auto tranny hold up(without rompin on it to much and frequent tranny oil changes, probably a tranny oil cooler as well)? Also itd be great if i could get some input from people who have actually done this. thanks in advanced
Old Jun 13, 2012 | 12:31 PM
metaphor51's Avatar
be water, my friend
Default Re: Need advice for a turbo automatic d series
BUMP!
I'm interested to know the answer/outcome of this...
Old Jun 13, 2012 | 01:08 PM
94EG8's Avatar
Seagull Management
What year civic? '96 - '00 basically can't be done due not being able to control the trans with an OBD1 ECU. '92 - '95 Can sorta be done, but you can't adjust the shift points and the trans wont like it.
Old Jun 13, 2012 | 01:53 PM
speedjunkie_g35's Avatar
From: Pensacola, FL and every Court House in Louisiana
Pounds of boost is irrelevant!!! What Hp are you going for? I would personally avoid it or do a 5 speed swap and let her learn
Old Jun 13, 2012 | 09:14 PM
i know pounds of boost doesnt matter lol but id like to get 190-220 hp out of her car. i know the motor will be fine and she knows how to drive stick perfectly fine but she wants to keep her car auto. Oh also its a 94 obd1 with a chipped ecu.
Old Aug 2, 2012 | 10:42 AM
Nitrous1024's Avatar
This sounds like a recipe for disaster on stock internals
With the HP numbers that you've posted above, that transmission will be absorbing a lot of the power output before breaking.
Old Aug 2, 2012 | 02:04 PM
Gearspeed-Performance's Avatar
I made 190hp on a completely stock EX SOHC with a Greddy kit and daily drove it for over a year. No issues. New owner never had an issue until he crushed the oil pan after hitting something on the highway a year and a half later. Would probably still be going strong. Was a fun car!
As far as the auto part goes..Mine was a 5spd. So I can't speak on that! Swap to a 5spd for longetivity would be my suggestion. All I did was rebuild the trans with new bearings, seals, carbon synchros and an LSD. Problem free! Just an idea to keep in mind....
Better yet...Do it and post up your results and be the first to post on this
Old Aug 2, 2012 | 02:55 PM
metaphor51's Avatar
be water, my friend
Yeah, just do it and see what happens...
Stevoyayaya3
Jun 14, 2012 10:31 AM
BOMBCRU
May 21, 2008 11:59 PM
twotonecivic
Feb 4, 2007 12:44 PM
eymnewdc4
Aug 4, 2004 06:53 PM
LSVTEC96HB
Dec 22, 2002 06:48 PM
