Honda S2000 Honda S2000
oversize cylinder bore, does it need to be tune?
Old Jun 13, 2012 | 09:45 AM
accord03coupe's Avatar
Default oversize cylinder bore, does it need to be tune?
hi, i mess up my cyliner due to running on low oil(careless mistake)
i was able to save it by just honed
piston and rod are still good, all i need is new set of rings
i went to dealer and new set of rings cost almost same of a set of wisco pistons and rings.
i was thinking if i bought the wisco pistons, why dont i go oversize because the are same price.
my question is, does it need to be tune if i go oversize?
thanks
Old Jun 13, 2012 | 09:47 AM
Dc4LsTeG's Avatar
EK9
Default Re: oversize cylinder bore, does it need to be tune?
Does it, probably not. Should it, YES
Old Jun 13, 2012 | 10:07 AM
rockwell23's Avatar
Wait until you get the pistons and take them and the rings to the machine shop with you. They will measure and bore accordingly.
Piston manufacturers do not go by a set standard in their sizes. They each vary. It best you wait!!!
Old Jun 13, 2012 | 10:38 AM
Boots's Avatar
i hope the shop you got to hone those cylinder walls know how to hone FRM sleeves or youre going to be burning some major oil when you get it back together
Old Jun 13, 2012 | 10:01 PM
HondaKyle's Avatar
You wont gain really any power if this motor is even done properly. You'll need a tune. Performance and low budget never end well.
Old Jun 13, 2012 | 10:14 PM
TJChad's Avatar
Do your research more, forged pistons in FRM cylinders = no go
Ep3tat98
K Series
Feb 3, 2016 10:20 PM
OldGrandpa
15
Apr 17, 2014 08:32 AM
ludelvr
Nov 26, 2003 03:56 PM
zCivic
May 14, 2003 09:59 AM
Plan B
Dec 10, 2002 07:40 PM
