d16a1 obd0 CEL 8
code 8 is for the TDC sensor - if your D16A1 is 86-87, the sensor is in fact in the crank angle unit on the end of the exhaust camshaft, however, if your D16A1 is 88-89, the TDC sensor is inside the distributor, not in the unit on the exhaust cam - hard to tell from your picture, but i am guessing you have 88-89 A1, which means you may need to be looking at the distributor to solve the problem
90RENOsedan
Dec 21, 2009 10:14 PM
