ep3: lights not flashing when using remote
i know they are supposed to blink when i lock and unlock the doors and also the horn honk when i push the lock button twice within a couple second.i checked and the fuses are good.. anyone have any clue on why it doesn't do what its supposed to?
My car stopped doing that too... it turned out to be bad for me... I ended up having to replace the fuse box as it went bad somewhere somehow.. so hopefully your problem is simpler than mine! Mine was an RSX not EP3 too
well found out theres nothing at all wrong.My alarm was in valet mode... To turn that off, get into your car shut the door, lock the door switch then unlock, then put your key in and out of you ignition 5 times then lock and unlock the door switch.. Use you remote to see if it works. I wish I new it was only that easy! Haha so i hope this is useful for others because people on other ep3 sites had no clue either. thanks.
89brokendownEF
Apr 17, 2016 05:36 PM
FrontwheelENT
Aug 17, 2012 08:59 AM
