1996 Del Sol small idle help?! (Project)
Old Jun 12, 2012 | 07:52 PM
buster023's Avatar
Icon3 1996 Del Sol small idle help?! (Project)
Hello i am new to these forums but i have read and seen many cool things so i just joined. But my issue is that i have a B16A DOHC Vtec motor that was swapped in the car before I bought it. Not so shocked but it has a small idle problem.
I am mechanically inclined too and here are the things I have done to either attempt to fix it or bring it down:
-Cleaned IACV
-checked for vac. leaks
-tighten the Fast idle valve
-tried to reset the throttle (but turns out if i turn the bolt to lower the rpms it actually doesnt change n i hear a pop sound increasing from my muffler, n yes it is aftermarket so its noticable)
-Checked voltage on the sensors
-bled the coolant system
-Also tighten bolts near the throttle body gasket and intake manifold
Now after reseting the ecu I plug the IACV back in and start it, it revs between 1000-1500 rpms steadily. No check engine light or anything. still no change.
But when i did it once and then drove around the block the IACV light came on and so did the knock sensor but i think that comes on because of how it runs. So could it be the IACV and the valve is stuck. Because someone I know who works at the dealer said a valve could be open? I am running out of ideas and don't want to waste money left and right that wont fix the problem.
...also its a jdm motor i believe and has no purge valve on the intake manifold but the wire and one of the hoses that comes from the charcoal chamber is just lying in the back. i dont know if that is bad or not?
any help would be greatly Appreciated!
Old Jun 14, 2012 | 05:01 AM
delsolintegra's Avatar
Default Re: 1996 Del Sol small idle help?! (Project)
Is the IACV gasket in good shape? I always refresh mine with silicon grease when I reassemble. There are other o-rings like in the FPR that I treat with the grease.
Old Jun 14, 2012 | 03:29 PM
buster023's Avatar
yea i cleaned that out and everything, turns out i have a vaccum leak where my pcv valve is there was no tube going in or out the breather chamber. lol so ill see if that helps it. thanks tho!
xChrizcrozzx
Mar 2, 2017 01:42 PM
sorullo
Feb 25, 2009 06:53 PM
93turbotegSAV
Apr 2, 2007 05:46 PM
DJ_SaNdOz
Mar 4, 2003 08:34 AM
pdiddy
Dec 10, 2002 10:47 PM
