Question about Vertex Wheel & NRG hub
Old Jun 12, 2012 | 05:56 PM
hybridnorth's Avatar
Default Question about Vertex Wheel & NRG hub
I recently just purchased a Vertex wheel and a nrg short hub, my question is the the horn button wont lock into place. The center of the nrg hub is too big for the horn button to fit. Has anyone tried using a momo horn ring to make it seat properly.
TIA
Old Jun 13, 2012 | 09:31 AM
BC_Garage's Avatar
Default Re: Question about Vertex Wheel & NRG hub
Normally the horn button snaps into the opening on the middle of the steering wheel and is not affected by the hub.
Old Jun 13, 2012 | 09:58 AM
Captain Key!s's Avatar
Not true...the short hub is merely a hub for the NRG quick release. The quick release is what you bolt the wheel to.
The horn button does not fit to the wheel, only to the hub (quick relase in this case). You either need to get the QR or get a standard MOMO hub for it to work properly.
Old Jun 13, 2012 | 03:05 PM
Perfect thanks for the replies. I also did some more digging and momo makes a horn retaining ring that has the same bolt pattern as the wheel/hub and the inner diameter is the same size of the horn button. This should hold the button in place, I ordered it and will try it out.
Old Jun 14, 2012 | 12:58 PM
DC4KiD's Avatar
Didn't have a problem with my Vertex/NRG setup:
Old Jun 15, 2012 | 08:49 AM
I took a closer look at my horn button and it has been trimmed to fit the previous owners hub, and I found measurments for a brand new horn button and un-trimmed it would fit the nrg hub.
If anyone else runs into this the momo part number is #retring and I found it on ebay for $9.95 shipped!
Thanks for the picture!
93egallmotor
Dec 30, 2010 11:44 AM
korndog
Mar 25, 2008 12:47 PM
captain_crunch
Mar 11, 2008 01:20 PM
Mistermark
Feb 28, 2006 02:52 AM
MattP
Nov 25, 2004 03:04 AM
