Modified Clutch Question
Hey all, my trans exploded in my Rex so I removed it and upon removing the stock clutch I noticed this ...
Could someone tell me what the purpose of doing this is? I've never seen anything like it before and it puzzles me as to what the reason behind it would be.
Thanks.
PS...Sorry the picture is probably taking up your entire monitor...Droid cam ... Idk.
Thanks.
On another side note, anyone know the easiest way to get stubborn flywheel bolts broken loose? They're short top bolts so I can't get my socket to hold on to it. I don't know if they make a special socket for em but I've just been trying to use my twelve point socket. Just every time I put any sort of force on em the socket pops right off. Annoying. But yea if anyone has any useful tips it'd be appreciated.
I have a 17mm 12 point socket I turned on a metal lathe, I cut the rounded edge of so it grabs better, makes a big difference. Also, an impact gun will normally take those bolts right out.
I still wanna know wtf is up with this clutch.
Where'd ya get em?
Hmm, this might explain something: http://www.saabcentral.com/forums/ar...p/t-82793.html
Now being the car is n/a right now as opposed to the boosted cars in that saab forum, I could understand now why he welded the fingers, whereas in terms of a boosted car, doing this would only provide a marginal increase in the clutch's ability to hold that kind of power.
So to conclude, welding the fingers like that actually is an idea, for someone who has a Honda (in this case) that has been boosted and isn't making phenomenal power. It's cheaper than buying a new clutch and can still hold more power than a stock clutch. The fingers are welded in spots so as to not add extra weight which can actually rob power. But it makes the fingers wider in a sense, making them stiffer and causing them to apply more pressure to the friction disc and thus handling more power. Apparently my rex used to be boosted, so this mod answers more of my suspicions. Again, for someone with a low budget that has a stock motor with either lots of bolt ons or a low boost turbo kit, this mod is actually a sound idea to save you some money until you can afford a new clutch.
That thread helped a lot, I really appreciate it.
^ That was the thought, I don't think it actually works though. And like someone on that Saab forum mentioned welding on the fingers will destroy the temper of the metal.
I ran the car at the track like this, before the trans blew out, and even a full throttle dump with that trans on sticky tires it hooked and took off, no clutch slip or anything. I mean stock motor yea but it ran a 14 dead on a stock clutch so I mean maybe in this rare instance it might have worked. Oh well, getting an lsd trans and staged clutch to play it safe. Glad you found that article, helped answer a lot of questions, thanks much.
