91 Accord engine swap 94 Vtec
Hello I have a 1991 Accord also have a wrecked 94 accord both automatics looking to put the Vtec In the 91. Can It be done any and all help would be greatly appriciated. Thanks aaaaaaaaaaall
This might help you out a bit!
http://www.cb7tuner.com/vbb/showthread.php?t=138663
and some general swap knowledge; http://www.cb7tuner.com/vbb/showthread.php?t=5423
http://www.cb7tuner.com/vbb/showthread.php?t=138663and some general swap knowledge; http://www.cb7tuner.com/vbb/showthread.php?t=5423
The F22B1 is a solid reliable engine that, when taken care of, will give you pretty good performance (145hp and 147 lb-ft tq) and fuel economy.
https://picasaweb.google.com/1115434...53710889202178 both cv's are out all wireing Is unpluged all fluids drained hoses removed all 4 main mounts are loose. This took me about 6 hrs and a 12 pack ready to pluck It out.
If ur fuel rail and multi port injection isnt JDM on either one u should be fine but usually I could be wrong but if u just sway ur lines shouldnt be off by much u may need to get creative!!!
dcskater56
May 14, 2007 08:47 AM
