na b7y8 mini me build
Ok extremely new to honda world one thing I did learn from my cuz is for pa emissions turbos normally don't without a lick n stick sticker. So with that I have a 96 ek hatch with a b7y8 mini me in it ( I believe). All I want is 120 ft lbs of torque on all motor setup if anyone has done this please pm me to help with build. Realistically i know nothing about motors but I can tell that on the car it has headers highflow cat fart can and eBay intake. Any advice I got all the time and 2000 bucks.
hmm for $1000 you can swap a b20z in it, and have 147 HP and 133 torque
any b series goes right in
all you need for either of the two (technically the same engine)
engine and trans (i suggest a b16 tranny tho :3) i think the only thing differnent with the mount is the rear T bracket (needs to be from 99-00 si)
you can use your stock harness (convert 3 wire IACV to 2 wire) and MIGHT have to change the CPK (sp?) sensor plug.
axles, you use stock integra axles, and a B series shift linkage. and the integra ECU, OBD2 plugs right in.. you MIGHT need to repin something, but shouldnt have to on a non-vtec engine.
personally i've never done a b series swap, but i've gone D>D and D>H and its nothing more than a d series swap technically.
Ok so i dont wanna start anything on the forum but from personal experience only out of these three which is the best to get motor/tranny from Hmotors ; JDM Engine Depot ; JDM Tiger
I personally choose Hmotorsonline. Steve is an awesome guy ( a bit hard to understand sometimes haha) he has hooked me up a few time on miscellaneous RHD parts (rack and pinion, steering U joint, pedals, dashboard etc)
This is the type of post I just don't get - where are you getting those prices? I went to the three websites listed below the post I'm quoting, and a swap is just short of 2 grand. Where are people getting swaps for those prices?
hAlp.
hAlp.
b18b1 is found in 94-01 integras
b20b is found in 97-98 CRV
b20z is found in 99-00 CRV
you can get the engine for $400-600
transmissions run about $200 for an LS $400-$600 for a B16
mounts are the same i believe!
axles you can usually get with the transmission, if not they are roughly $30 a piece, plus $25 for the half shaft. and $100 or so for an LS or Crv ECU.
you can easily spend as little as $1000 on a swap, or spend more if you want nicer higher performance stuff.
if you want some cheap power, give this a try.
http://www.hmotorsonline.com/shop/sc...age&item=30013
Remember that the B20 is federally classified as a light truck motor, and depending on how restrictive your state inspection is, technically should not pass.
chevy 350 is a truck motor
but they also put it in cars.
same with the ford 2.3L. they put them in rangers, then into mustangs
Anyone got some great junkyard dog posts?
just make sure you get the engine from a yard that has tested it, and provides atleast a 30 day startup warranty. ask if they ran a compression test, and leakdown test, and ask for the results in writing.
I can't speak to all states, and I definitely can't speak to all localities, but yeah, California is the worst for it.
and its not hard to put in either. its the same as doing an H22
need engine, transmission, cable shifter and shifter box, H series EK mounts, and axles are custom. hasport makes them, or you can do i think its Integra inner CV's, accord axles, and civic outer CV's???? i can't remember,
then the ECU, and you can use an EX harness, and use the ecu. and the exhaust is close but needs to be extended 2"?
BUDiiE_B0ii
Aug 13, 2007 06:03 AM
Pnoyej6
Northern California (Sales)
Dec 1, 2006 01:30 PM
