putting skunk2 on my gsr need help pls
Hey guys I need help install my skunk2 manifold in my car, I'm not sure where i got to connect the hoses to, theres one on the right top and in the back.
need help pls thanks
This might help
http://www.clubcivic.com/board/showthread.php?t=108068
This might help
From: Pensacola, FL and every Court House in Louisiana
I think I ran the nip on the back to the evap canister.
Yes you need it if you have a gsr. There is no getting around it. The Type r throttle cable is also shorter because of the way it is routed across the intake runners.The way the gsr throttle cable bracket is placed above the throttle body and will hit the hood. Just look at the way a stock gsr intake is compared to a type r and you will see what I speak of.
You can use your stock gsr throttle body and throttle cable no problem. Some people choose to use a standard B series throttle body and ITR throttle cable as it looks cleaner.
I just used my stock GSR PCV and hose and it worked fine
That is correct, I was thinking more of the cable bracket that bolts to the runner in needed. $40 bucks for both cable and bracket, why not?
I have to say I don't like how "touchy" the type r.cable is compared though.
I used the pulley off my VX. What do you mean touchy? I would consider mine to have a touchy throttle response. I don't see how a throttle cable would cause the throttle to be touchy. What pulley are you using? That is the only thing I could see making a difference.
I used the pulley off my VX. What do you mean touchy? I would consider mine to have a touchy throttle response. I don't see how a throttle cable would cause the throttle to be touchy. What pulley are you using? That isthe only thing I could see making a difference.
vboy714
Jan 18, 2005 01:45 AM
eg6hatch
11
Feb 12, 2004 06:20 PM
