Well...went to the dyno again...after changing injectors.
Well...since I was last at the dyno(https://honda-tech.com/zerothread?id=269935) I removed the FPR that was lent to me and installed some '97+ Prelude injectors(290cc/min)...lets just say that I was running a little on the rich side:
Here is what I looked like the last time that I was at the dyno and what I look like now...got some nice gains, the CF were both 1.00, temp was 79.99 vs 79.40, pressure was 29.75 vs 29.68.
and here is the pre-HyTech vs current tuned HyTech:
Link to all of the plots, and higher resolution shots:
Austin - who is very tired from his long 1400 mile road trip
Very impressive. What type of setup are you running?
Austin
Hmmm. It's interesting that you've gained power in the midrange where the stock injectors should still be doing OK, but have no gains in the top end where (from what I've seen) they cannot keep up. Not at all what I expected.
Austin
What does the Hytec header and exhaust cost? If you do not want to post it, please PM me.
$1300 for the header
$950 for the exhaust with the integrated cat
Current shipping time is 2-3 weeks.
Austin
Currently prices from John at HyTech:
Austin
Austin
Austin
Austin
I guess for the performance gains (NA) it is worth it, but I cannot afford one
As much as I love NA,for that type of coin, a decent turbo setup is not much more money
to all those who poopoo keihin pintle nozzles, I'm sorry but the better spray pattern [than the disc type nozzle] must give a better mixture quality and the reason you see the low to mid rpm improvements from a better burn at those rpms....
[Modified by Michael Delaney, 11:12 PM 10/14/2002]
some of the FI guys tell me that the disc nozzles tend to flutter at high cylinder pressures and stick open as well...anyone else have any injector stories to share? nozzles, drivers, ECU tuning with certain brands, etc.
It's funny. When I looked at Jun's stage 4 N/A crate motor rated at 240-250 ps they sell over on their Japanese website, guess what size injectors they use? it ain't 370's or 440's, I can tell you that....
Hey Austins can ya fill me in? why did you get rid of your Toda set-up?
running stock ITR cams now right?
The stock cams prove to be working quite well with the proper selection of supporting parts, and tuning...the most important part is still tuning.
Austin
Austin should drop in some Toda Spec A's and call it a day
Nice post, good info
Austin
very good power austin!
good gains on those mods...
and plus, ur engine is more reliable than with those todas...
ahh, maintenance!
ahh, maintenance!
