Stereo Issues.
Old Jun 9, 2012 | 08:29 PM
xo1996hondaxo's Avatar
Default Stereo Issues.
hey everyone. i have a 1996 honda civic that im attempting to hook up a pioneer head unit to, i connected all the wires and it seems that on the plug that connects into the factory harness has one additional wire (orange and white stripped) and its called "positive dimmer" for some reason, my head unit has NO POWER, no lights, no NOTHING...
if anyone could help me out id appriciate it!
Old Jun 9, 2012 | 08:35 PM
92lxsleeper's Avatar
Default Re: Stereo Issues.
some headunits have that wire, others dont. including yours.
you should have 3 wires that control your power
Yellow
Red
Black
Black is ground obviously.
Yellow is the constant B+
and Red is a switched B+ when the key is in accessory or run position.
what model civic do you have? you should check your wiring, the fuse on the back of the deck, and then the fuse in your fuse panel.
Old Jun 9, 2012 | 08:39 PM
have a 1996 civic lx and i checked the fuses and seems to be fine.. not sure what else to do?
Old Jun 9, 2012 | 08:51 PM
is the deck known to be good? unplug the harness from the back of the deck, and check for power.
Old Jun 9, 2012 | 08:52 PM
Brand new deck, just bought it tonight from best buy..... will test it tomorrow a test light, i dont have one at home right now :/
Old Jun 10, 2012 | 03:45 AM
grumblemarc's Avatar
The Grumpiest
Are you using a proper wiring harness to do the install or are you cutting and splicing? There should be no issues if you're using a proper harness. You should also NOT be splicing ANY wires into the dimmer switch/circuit.
Old Jun 10, 2012 | 07:43 AM
noz79's Avatar
There are 2 fuses for the radio on that car 1 under the hood and 1 under the dash.
DannyDeuce
Audio / Security / Video
May 10, 2006 08:16 PM
elmalouno
Dec 7, 2004 01:36 PM
Drakko
Aug 22, 2004 01:20 PM
NathanMorris
Jul 14, 2004 09:45 PM
wickedxbo1
Sep 21, 2001 08:35 PM
