Cheapest shocks?
Old Jun 9, 2012 | 07:24 PM
Confessed's Avatar
Default Cheapest shocks?
Are the Toxico HP blues about as cheap as it gets? Just got my EP3 a few weeks ago and the one thing that kills me is the horrible shocks it's got. Bouncy as a ****.
Edit: Better question. Are shocks the answer to stop the bouncing? Basically all bridges and bumpy roads make the ride unbearable. Things in the hatch will fly up in the air it's so bad.
Last edited by Confessed; Jun 10, 2012 at 05:29 AM. Reason: Realized that original question has probably been asked 20 times
Old Jun 11, 2012 | 10:33 AM
Confessed's Avatar
Default Re: Cheapest shocks?
Help a noob out...just need to know if I need shocks/springs/dampers any info
Old Jun 11, 2012 | 10:38 AM
SickSi99's Avatar
Get some Koni Yellow adjustable shocks. They allow you to adjust them according to your style.
Old Jun 11, 2012 | 11:09 AM
Confessed's Avatar
So shocks are indeed what I need. I should also mention that the previous owner said it was on lowering springs.
What is the part number for the Koni Yellow set I need? I can't find anything.
Old Jun 11, 2012 | 11:57 AM
SickSi99's Avatar
Ah yeah, go back to stock springs or switch to full coilovers. Might even invest in changing out the shock mounts.
Front: 8610-1416 50mm
Rear: 8041-1281 50mm
Old Jun 11, 2012 | 12:07 PM
Confessed's Avatar
I should have probably mentioned the budget. I really can't spend over $600 right now. So if I need springs I'd be looking at getting the Tokico blues($450) and some decent springs(with very little lowering, can't afford H&R OE sports).
Old Jun 11, 2012 | 12:25 PM
JuggerNaut-CTR's Avatar
Originally Posted by Confessed
So shocks are indeed what I need. I should also mention that the previous owner said it was on lowering springs.What is the part number for the Koni Yellow set I need? I can't find anything.
You still havent stated what your current set-up is? If the prev owner is indeed correct that they are even lowering springs. For all you know its bouncy because its on ebay coilover sleeves or the struts are blown. Who knows? Might be helpful to pull off a front and rear wheel so you know what you have first. Then come here with that info so people can give you real helpful input. Alot of people will tell you, just get these, or if you can afford these, they are awesome. If you have a budget and want to upgrade anyways, than whats the point of this thread?
Old Jun 11, 2012 | 12:48 PM
SickSi99's Avatar
^Truth. Pull off one of the wheels and snap an up close pic of your setup. Tokico's aren't bad if you're on a budget. KYB's are a good choice as well.
Old Jun 11, 2012 | 12:54 PM
Confessed's Avatar
I could stare at the setup all day and not know what I'm looking at. All my eye would see is some dirty springs(will take pics tomorrow). The point of the thread is to find out what the general consensus is for horribly bouncy rides and what is needed to solve the problem.
Good attitude, bro. Really helps a forum out.
Old Jun 11, 2012 | 01:38 PM
poeticfinesse21's Avatar
I was in the same boat when I bought my ep3. Previous owner put ground control sleeves with a 2 inch drop on stock struts. Lowering springs + stock struts = Blown shocks and that's most likely what's wrong with your car. I recommend you do what I did. I got a used DC5 Type-R full suspension with only 15k miles for $200 shipped off ebay. I got lucky with the price but you should be able to find a set for $300-$400. All you need to install is RSX tie rod ends and shave the rear shock bushings about 3mm each and the difference in handling is like night and day. Considering it only cost me about $300 for everything, it was more than worth it.
Old Jun 11, 2012 | 07:02 PM
Earthworm Jim's Avatar
Bargain prices = Bargain quality.
Old Jun 11, 2012 | 07:03 PM
Not saying buy anything super expensive but the shocks are your problem (to answer your question).
Old Jun 12, 2012 | 05:43 AM
Confessed's Avatar
http://imgur.com/VZDzM,1ypJc,Gz6FS,PtxdD,0Tddr,XJr16
Pics.
Old Jun 12, 2012 | 07:56 AM
SickSi99's Avatar
Can't tell what kind of springs those are or what shocks. Try and take one of the front wheels off and look for a brand tag otherwise we really can't help you.
Old Jun 12, 2012 | 08:02 AM
Up to the point I commented on this thread, I had given you the most useful and helpful advice. Not just telling you to go buy a $600+ set-up not knowing your budget. Was trying to find the real issue for you, and said it with absolutely no attitude at all. Re-reading my original post, I cant see any way you could have gotten butthurt about it...it was damn true dude.
Old Jun 12, 2012 | 08:49 AM
Confessed's Avatar
I did...hence why there are 5 pics of the front in the link I sent.
Old Jun 12, 2012 | 09:46 AM
SkoundrelUSA's Avatar
cute little bastard
looks like some cheapo no-name. But even with stock shocks and mild lowering springs (Eibach), it can still be a tad harsh. Nothing will ever be as comfortable as OEM. I'm currently running Eibach Prokit + stock shocks and its OK. Still can't really monster truck over manholes/bumps, but definitely better than my old Megan full coilover setup where I felt every pebble.
You can find used OEM shocks/springs around (www.ephatch.com or www.clubep3.net)
Old Jun 12, 2012 | 11:07 AM
Confessed's Avatar
A hard ride kind of what I want...I don't mind a harsh ride and avoiding potholes I just want the damn up-down-up-down bouncing to stop.
Old Jun 12, 2012 | 01:35 PM
SickSi99's Avatar
My Bad didn't see that. Yeah looks like stock shocks on no name lowering springs.
Old Jun 12, 2012 | 02:04 PM
http://forums.clubrsx.com/showthread.php?t=825696
http://www.ebay.com/itm/JDM-02-04-ACURA-RSX-DC5-TYPE-R-OEM-SUSPENSIONS-SHOCKS-S6M-/190670251993?pt=Motors_Car_Truck_Parts_Accessories &hash=item2c64d527d9&vxp=mtr
First link is RSX a-spec suspension, second is DC5 type-r suspension. Both fully assembled with top-hats. Both sets are stiffer than stock but still oem quality
Old Jun 13, 2012 | 12:02 AM
Confessed's Avatar
I don't think I can pass up that ebay link. Thank you.
Old Jun 13, 2012 | 06:05 AM
SickSi99's Avatar
Or pick up the HFP Suspension.
Old Jun 13, 2012 | 07:09 AM
cute little bastard
As for the original question, I think KYB GR2s might be cheaper.
Old Jun 13, 2012 | 07:55 AM
0c00l's Avatar
I bought a set of 4 KYb's for my EM1 5 years ago, never had an issue. Just got them for stock replacement and love em! I paid 300 shipped.
Old Jun 13, 2012 | 08:09 AM
Mr. Spade's Avatar
Get racelands bro. They're the best.
