How tight should THIS and THIS be?
Just re-assembling my front end. I am using new upper control arms and new stabilizer endlinks and I am unsure how much to tighten them respectively.
For the upper control arms, there are 2 pivots on each, with a bolt and nut going through each pivot. I could probably tighten the nut hard enough to bend the metal and clamp onto each pivot and lock it inplace. But I dont think your supposed to do that, is there a tightness spec for it?
For the stabilizer end links, they are new beck/arnley units, just plain metal cups and rubber bushings. Again I could probably tighten the nut so hard that the rubber bushings squished to nothing. Is there a tightness spec for these or simply when it feels like all bushings are "solid"??
Thanks for the help guys!
Loosen those end links they are tooo tight. there should be about 1/8 inch of threads sticking out. As for the upper control arm there is a torque spec for that.
You want the end links tight enough that there is no slop, the bushings may get a squished a bit, but you don't have to go nuts with it. They look fine to me.
Cool Cool Island Breezes. BOY-EE
Tighten the control arm nuts to about 50lbs (IIRC). But jack up the suspension first so you tighten them at about ride height. Always tighten pivoting bushings at ride height.
As far as the stabilizer link...I think I remember about a 30lb spec.
I tightenned them with the suspension drooped. Will this affect anything?
Like how you see it in my first pic is exactly where I tightenned it. That suspension level.
WIll that overclock and ruin my bushing? I havent driven the car yet, but I still dont see how any tools would fit up in there to tighten it with me being lowerred 2", just no room in there at all from what Im seeing.
Hoping how I did it, is fine
I agree there is a torque spec for both but I have yet to torque a end link. To me it works and will continue to, but to some its completely wrong. Either way its up to the OP to decide what he wants to do.
For DC/92-95 Civic upper arms, I tighten the bolts while the arm is out of the car. It looks like 88-91 arms are a similar design. I just kinda guestimate the angle the arm will be at ride height and tighten the bolts. Then I install the arm. It's a bit of a struggle to install...but leaving the 2 top nuts loose till you get the ball joint started helps.
an2ny888
Sep 2, 2006 05:56 AM
dohc_profile
Jun 6, 2006 02:46 PM
