type r turbo help
Old Jun 8, 2012 | 05:12 PM
Haccord1996's Avatar
Default type r turbo help
I just installed a turbo setup b18c type r into my 2000 coupe 650 cc 3 bar map and running p28 with a basemap for my setup already
problem is its running rich at idle can i get some help???
wideband shows 9.5 at idle
Old Jun 8, 2012 | 05:17 PM
Dc4LsTeG's Avatar
EK9
Default Re: type r turbo help
Get a tune
Old Jun 8, 2012 | 05:33 PM
i know that but shouldnt my car at least idle without me having to keep my foot on the acel pedal?
Old Jun 8, 2012 | 05:34 PM
civickiller's Avatar
Originally Posted by Dc4LsTeG
Get a tune
+1
Old Jun 8, 2012 | 05:46 PM
doood's Avatar
been there done that
what's your fuel pressure?
Old Jun 8, 2012 | 06:10 PM
Dc4LsTeG's Avatar
EK9
Idk no one here knows what your basemap looks like
Old Jun 9, 2012 | 06:51 AM
grumblemarc's Avatar
The Grumpiest
Your basemap could be ***. Get a tune.
Old Jun 9, 2012 | 02:17 PM
chris from xenocron did my basemap 3 times and my fuel pressure is at 43.5
Old Jun 9, 2012 | 02:41 PM
The Grumpiest
Then it's probably to just get you to the tuner and not lean out while you're on the way there. In any case you need a tune. No getting around it. No need to even try and troubleshoot any fuel issues until you do.
Old Jun 10, 2012 | 04:58 PM
xenocron's Avatar
If this is the gent that came up on Friday...the basemap that was in the ECU was done by someone else, and the person that that brought the ecu in didn't have much info on the car...thought it was 750cc injectors. (which should make the car leaner, not rich)
My guess, you have different injectors than you think you do or you have some sort of wiring or mechanical issue perhaps...especially if you have tried three different basemaps without luck
Old Jun 10, 2012 | 05:07 PM
The Grumpiest
Hm. Would explain things.
Old Jun 10, 2012 | 09:06 PM
Mike Lowwryyy's Avatar
Chris has alot of patience... lol.
OP... What Software you running? I might be able to help
Old Jun 11, 2012 | 01:51 PM
xenocron's Avatar
I think we figured out the map sensor is faulting high, shows 4.6+ volts with key on, engine off according to the shop working on it. So I think we have found the problem
Old Jun 12, 2012 | 06:51 AM
The Grumpiest
Cool. If you guys were working on it, I don't understand the need to have even started this thread.
S2kjulian
Sep 5, 2017 09:41 AM
si90rex
Engine Management and Tuning
Oct 23, 2011 03:13 PM
Ehop
Sep 9, 2006 04:30 PM
dublaaciv
Nov 1, 2005 07:08 PM
SCedGTP
Apr 10, 2003 11:54 AM
