Ignition problem
I have a B16A2 that is throwing code 8 from my obd1 ECU. I have changed the distributor 3 times now and the code will not go away even after the ECU has been reset. It also miss fires fairly bad as well. The distributors work fine on another B16 but for some reason, they seem to dislike my car.
Is there anything else that could be the issue?
I really hope its not my ECU. I just had Phearable install a Hondatq in the P30.
hondatuner77
Aug 8, 2010 09:21 AM
