How hard to change auto tranny with new tranny?
Old Oct 14, 2002 | 09:53 AM
KevronsEG's Avatar
Default How hard to change auto tranny with new tranny?
it has bad auto i've changed manual but what the diff. between the two.
Thanks
Old Oct 14, 2002 | 10:27 AM
Stupid Ass's Avatar
Default Re: How hard to change auto tranny with new tranny? (CIV616)
Huh?
Old Oct 14, 2002 | 10:34 AM
crxgurlllll's Avatar
WTF?........
Old Oct 14, 2002 | 10:37 AM
EP3_05's Avatar
You might want to rephrase your question so we can understand what you are trying to say.
Old Oct 14, 2002 | 12:26 PM
APEXI Si's Avatar
Default Re: How hard to change auto tranny with new tranny? (91civic)
i think he means it has abd auto tranny and he wnats to replace it. hes changed manual trannys and wants to know what the diff. is between the manual swap and doing a auto swap.
Old Oct 14, 2002 | 12:35 PM
Stupid Ass's Avatar
Default Re: How hard to change auto tranny with new tranny? (crx616)
Are you the same person or something?
You will need a manual ECU, new pedalboard, clutch, tranny, flywheel... you will need to put something in where the old shifter went so water and stuff doesn't come in, tack weld a piece of sheet metal or something... thats about it.. make sure you do the appropriate wiring also, or the car won't start.
Old Oct 14, 2002 | 01:15 PM
KevronsEG's Avatar
Default Re: How hard to change auto tranny with new tranny? (SOHC NoTEC)
no no no i wnat to replace it with a auto tranny. i have swaped manual tranny but never and auto what is the diffrence between doing and manual to new manual to a bad auto to a good auto. like no linkage tere are cables and no clutch there is a converter
Old Oct 14, 2002 | 03:01 PM
KevronsEG's Avatar
umm
Old Oct 14, 2002 | 06:15 PM
the DR.'s Avatar
its not hard, unbolt the old one and bolt the new one on... make sure you line the torque converter up good..
Old Oct 14, 2002 | 08:45 PM
Stupid Ass's Avatar
Default Re: How hard to change auto tranny with new tranny? (CIVICtypeS)
Dude... go to grammar school first..
Second, do the reverse of what I said...
But make sure you do step one... before anything else.
Old Oct 14, 2002 | 09:42 PM
Malgerus's Avatar
HoOkEd On PhOniCs WeRkeD 4 ME!!!
... sorry, that was useless.
Old Oct 15, 2002 | 05:09 AM
KevronsEG's Avatar
hey sohc novtec you didnt even answer teh question. i asked about replacing the tranny not auto to man. swap. you need to learn to read the question before you answer it
Old Oct 15, 2002 | 07:43 AM
Stupid Ass's Avatar
Your questions make no sense god dammit...
If you want to take the manual out off of the block then remove the bolts holding it in... make your questions clear man.. im serious, your questions make no sense..
You said "what do I need to change the tranny and what do I do".... well doing the manual to auto is EXACTLY the opposite then doing the AUTO to MANUAL... just reverse it...
stunna!
Old Oct 15, 2002 | 01:20 PM
KevronsEG's Avatar
you dotn understand i'm not doing and auto to man. not auto to man.
get it
i'm replacing the auto with new auto old auto out new auto in.
i've done a old man. to new man. but never auto to auto. i wnated to know if there was any diff. from doing and man. to man. and doing and auto to auto like linkage and cables. you dotn understand
Old Oct 15, 2002 | 02:15 PM
Stupid Ass's Avatar
If done tons of swaps before, trrannys, motors... trust me, I understand...
What you fail to understand is that your making no sense with your sentences... you dont know proper grammar... so I cant answer your question...
Ok?
Old Oct 15, 2002 | 02:17 PM
Stupid Ass's Avatar
If your just changing out an auto for another auto, all you have to do is disconnect everything on the tranny... drop the tranny and then put the new automatic tranny in, and then reconnect the things you pulled off of the bad one!
Get it moron?
Old Oct 15, 2002 | 03:17 PM
Skillfactor's Avatar
Banned
*confused* are you missing a few fingers, preferably, the ones you type with?
Old Oct 15, 2002 | 03:25 PM
MTK Kommander's Avatar
Default Re: How hard to change auto tranny with new tranny? (skillfactor)
LMAO..this thread is CLASSIC.....
[Modified by MTK Kommander, 4:26 PM 10/15/2002]
Old Oct 15, 2002 | 04:19 PM
4-1-1's Avatar
WTF!!>!>!?!?!?!?!
Old Oct 15, 2002 | 04:26 PM
shortyz's Avatar
Default Re: How hard to change auto tranny with new tranny? (4-1-1)
hahahahahhaahhaahahh
MAN! MAN MAN!!!!
its not hard man, man in the man.
Old Oct 15, 2002 | 04:46 PM
LordVtec's Avatar
get it
So let me see if i follow because i just recently fell head first off the roof of my house and you are finally starting to make sense... correct me if i am wrong but what you are trying to say is that you have done an old man, and now want to do a new man, but want to know if doing an old man is any different than doing a new man?? You dont need Honda Tech.. you need a dating service.. heh heh heh
Old Oct 15, 2002 | 05:00 PM
j.Ngo's Avatar
dont worry guys.. i speak his language.... i'll translate it for you guys....
[quote]no no no i wnat to replace it with a auto tranny. i have swaped manual tranny but never and auto what is the diffrence between doing and manual to new manual to a bad auto to a good auto. like no linkage tere are cables and no clutch there is a converter[quote]
No, I want to replace it with a automatic transmission. I Have a swapped manual transimission..... but never have I had/or done a automatic swapped/swapping....What is the difference in the swappings? bolts? etc etc. here is what my car has been through so far
History: My car had a bad manual transmission so i replaced it with a new manual transmission... and then it had a bad automatic... and now what the **** i dont understand him either... oh well i tryed... hahaha
if you ever need me to decipher anything again...
you know who to call... J.Ngo The Grammer Police
Old Oct 15, 2002 | 05:11 PM
LordVtec's Avatar
Default Re: How hard to change auto tranny with new tranny? (j.Ngo)
LMAO...
Old Oct 15, 2002 | 05:28 PM
nEoMuGen's Avatar
Default Re: How hard to change auto tranny with new tranny? (LordVtec)
I will print out this thread and save it in archive folders. So when my kids start to do drugs and joining gangs whatever, I'll show them the printout and tell them "Stay in School!"
Old Oct 15, 2002 | 07:47 PM
l0p3z's Avatar
the bold phrase cracks me up!
[Modified by l0p3z, 10:48 PM 10/15/2002]
