Idle to low after reaching head gasket
Old Jun 8, 2012 | 07:51 AM
worx's Avatar
Default Idle to low after replacing head gasket
So I replaced my sisters head gasket on her gsr sedan last night. The idle is real low under 500 it's 1k when I start it then fluctuates between 200-1k but stays on the lower part for the most time if I rev it or drive it when I come to stop or clutch is pressed at a stop it will just drop the idle and die. Any help is appreciated I already checked the timing ignition timing as well cleaned the iacv it has a blox im and a 70mm TB do there is no idle screw
Old Jun 9, 2012 | 07:41 AM
worx's Avatar
Default Re: Idle to low after reaching head gasket
Wire for injector clip was broken.
crazyboy
Dec 29, 2012 06:46 AM
1250b18c5
21
Oct 9, 2011 08:31 PM
twentyhurtz
Jan 16, 2009 08:30 AM
arielb1
18
Dec 14, 2004 09:57 AM
