tranny cable????
Old Jun 7, 2012 | 09:47 PM
ZXiPoZ's Avatar
Default tranny cable????
Hi there,
Does anyone know the cable which connect to the tranny at the bottom of the tran, its at the middle for '02 accord?? My friend told me that is the transmission cable, and it should be check when we replace tranny fuild?? Any suggestions?? How could we remove it, and check it if its broken or not??? Thanks a lot
Old Jun 7, 2012 | 10:05 PM
jdmcertified909's Avatar
Default Re: tranny cable????
Originally Posted by ZXiPoZ
Hi there,
im guessing your talking about the passenger cable? http://autorepair.about.com/library/a/1i/bl630i.htm
http://www.2carpros.com/questions/ho...and-adjustment
Old Jun 7, 2012 | 10:34 PM
ZXiPoZ's Avatar
Originally Posted by jdmcertified909
There are 2 cable on the throttle body control, one is go into the gas pedal, what is the other one go???
Old Jun 8, 2012 | 06:25 AM
to the transmission follow it
Old Jun 8, 2012 | 11:25 AM
ZXiPoZ's Avatar
Mine is 4cyl, automatic, so I guess its a cruise cable, but not sure. I did follow it, and it connect to a black sphere ( thats NOT pretty sphere but kinda)
Old Jun 8, 2012 | 11:52 AM
what your looking for on your transmission is this http://www.sunrisejdmmotors.com/imag...RLCsNACT3S.jpg but yours might not have it since your obd2 i could be wrong long time since i have worked on one of t those
Old Jun 8, 2012 | 12:25 PM
ZXiPoZ's Avatar
uhm...but for mine, the cable doesnt locate at front, if you get underneath the car, you will see it, its right in the middle of tranny
Old Jun 8, 2012 | 02:30 PM
thats the shifter cable it shouldnt need adjust ment if the cars gears work on ever setting d1 d2 d3 d4 r p work right and the handle syncs with the letters then leave it
Old Jun 8, 2012 | 02:43 PM
ZXiPoZ's Avatar
Yeah, I just clean that one a bit, cuz it has white stuff cover w it. I got really struggle to find the tranny cable, just CANT find where the heck it is
Old Jun 8, 2012 | 10:24 PM
MAD_MIKE's Avatar
MM Gruppe B
Only the 90-97 Accords have the down shift cable.
'98-'02 are completely electronically controlled.
The cable mounted to the bottom of the transmission that is near the center of the car, under the bellhousing is the gear selector cable. I think Honda calls it a 'control' cable.
No adjustment is needed if for every gear you select the transmission is in that gear and the gear selector on the dash lights up.
90-97 cars with AT can have up to three cables attached to the throttle body.
1- Throttle cable from accelerator pedal
2- AT down shift cable(automatics only)
3- Cruise Control connects to a diaphragm. (optional)
98-02 cars with AT will only have two.
2- Cruise Control connects to a diaphragm.(optional)
There is no adjustment with the 98-02 transmission.
Old Jun 8, 2012 | 10:33 PM
ZXiPoZ's Avatar
YEP, absolutely TRUE. With that "control" cable, we cant adjustment it also, cuz there is no bolt on that, and it was put in that position, no way to move it around :D
THANKS FOR ALL YOUR HELPS. I DO APPRECIATE IT
BigDawwg6969
Feb 25, 2006 05:35 PM
joey1320
Feb 20, 2003 01:19 PM
