Weird Turn Signal Problems, Out of Ideas
Old Jun 7, 2012 | 06:03 PM
forneyhatch's Avatar
Default Weird Turn Signal Problems, Out of Ideas
I recently removed my OE wheel and intalled a Momo Steering wheel, NRG short hub, and NRG quick release. Also, I replaced my CX engine wiring harness with an EX engine harness. Now, my turn signals will not work. The SRS is currently disconnected. I checked the fuses under the hood and under the dash and they appear fine. Lastly, the weirdest thing is happening when I want to start or turn off the car. The car will not start or turn off unless the hazard button is pushed in. I can totally remove my key and the car is still running. Can someone give me some input on my problem? I am baffled. Thanks.
Old Jun 8, 2012 | 05:33 AM
grumblemarc's Avatar
The Grumpiest
Default Re: Weird Turn Signal Problems, Out of Ideas
Why?
Old Jun 8, 2012 | 04:21 PM
I replaced my CX harness because it was hacked up by the previous owner. Any suggestions on my problem? Thanks
Old Jun 8, 2012 | 05:00 PM
Blacknight117's Avatar
How `bout this, why not get another CX harness? More than likely may fix your issues..
Old Jun 10, 2012 | 03:47 PM
Hmm, thanks for everyones' ineffective comments. I chose an EX harness for my B series VTEC cause it is a better match. I don't plan on removing it.
Old Jun 10, 2012 | 03:57 PM
crawfo661's Avatar
Your problem is not in your engine harness. It is in your steering column. I would take everything back apart and make sure you have everything plugged in correctly and no shorted wires. why is your srs dis-connected?
Old Jun 10, 2012 | 03:58 PM
My momo steering wheel eliminates the airbag that the SRS cable is connected to
Old Jun 10, 2012 | 04:03 PM
The Grumpiest
So lemme understand. It was working PRIOR to the install of the Momo/NRG stuff and engine harness?
BTW. You're supposed to list ALL the car details in the first post. You could get your thread locked if you don't. This saves having to ask so many "ineffective" questions and upsetting you.
Sounds like some miswiring or more hacked up wiring underneath the dash.
Old Jun 10, 2012 | 04:08 PM
Hmm, I thought I mentioned all the details initially. Ill check under the dash and steering column again. Thanks.
bluebird
May 25, 2007 08:13 PM
GreenBean
Aug 10, 2002 05:56 AM
