Help!!
Old Oct 14, 2002 | 09:28 AM
Superhatch's Avatar
Default Help!!
Just swapped my old sohc zc into my new hatch (formerly Ausmiths/MugenMikes)
problems: exhaust leak even with new ex. manifold gasket, tach jumpy (not all the time), Car stutters when accelerating swiftly, at low rpm its allright.
1. I used the DC sports header on my longblock, will a stock honda gasket do?
2. After a bit of driving engine light comes on...due to exhaust leak?
3. Put in a new battery, but it seems like its dying...when I first started it the battery light came on, so I tightened the alternator belt up a little and it went away...could the alternator still be dead w/o the light coming on?
Any help is appreicated guys...I really need this thing to get running!
-Jake
Old Oct 14, 2002 | 09:40 AM
Superhatch's Avatar
Default Re: Help!! (SuperHatch)
Bump....
Old Oct 14, 2002 | 09:42 AM
EP3_05's Avatar
Could be the flange on the header is not level. The stock gasket should seal it up fine. What code is the ecu throwing when the CEL comes on?
Old Oct 14, 2002 | 10:41 AM
keithv's Avatar
Default Re: Help!! (91civic)
usually a jumpy tach is from a bad igniter or bad connections on the igniter...but you said the car hesitates, so maybe check the coil pack.
Old Oct 14, 2002 | 11:03 AM
Superhatch's Avatar
Default Re: Help!! (breaka_1_9)
Getting codes 1 and 20 ....so its gonna be a new O2 sensor I guess. Honda OEM $195 Checker auto: $42...hmm tough call.
-Jake
Old Oct 14, 2002 | 12:11 PM
Mr Ludecrs's Avatar
Whoa, Honda Genuine is expensive... The Honda dealer wanted $973 to replace my axels and cat back exhaust on my 91 Civic... uhh, my Civic isn't even worth $973
Jake, you check all the regular tune up type stuff (plugs, wires, cap, rotor etc)?
Old Oct 14, 2002 | 02:01 PM
ZCcivic91's Avatar
Default Re: Help!! (Mr Ludecrs)
Okay, if you ever figure out your code 20 is, PLEASE post what it was, Ive had one for almost a year now, and its pissing me off to no end!!!
Old Oct 14, 2002 | 05:07 PM
altoid's Avatar
Default Re: Help!! (ZCcivic91)
http://tech.hybridgarage.com/tech/codes.html
code 20 Accord Civic CRV CRX Del Sol Odyssey Prelude
year: 90-98 88-98 97-98 88-91 93-97 95-98 92-98
Electrical Load Detector
defective circuit or unplugged / defective sensor
rich4316
Honda Civic (2001 - 2005)
Oct 7, 2017 07:52 AM
Cain1977
Jul 9, 2016 08:56 AM
h3rsh3y2001
Jun 14, 2009 02:35 AM
SOHC_me
13
Jul 10, 2006 12:45 AM
xsellxoutx
Apr 23, 2004 02:52 PM
