Can I remove the plastic behind the cam gears?
B18b1, bent the **** out of it, Can I remove it without problems? I think yes. Also, when installing the head gasket, which way do
The indents around the coolant and oil passages face, the block or head? The gasket has no markings.
Thanks
Thanks
it's fairly only one way fit's. there is a part of the gasket that has number's on the bottem left hand side.
they should be faceing up. there is also a UP mark on the gasket that should be on the exhaust side.
and yeah you can remove the timing cover's but if something was to get stuck in there you could have big problem's
the bit were i said there are number's, im gessn it's a multi layerd steel gasket.
they are on the secound part of steel on the gasket. if you have them make sure they are
on the left hand side faceing up
hatchet_honda
Sep 10, 2010 05:17 AM
boosted ek
Jun 27, 2005 07:01 PM
