Tranny bracket doesnt line up??? FRUSTRATION!!!!!
Old Jun 7, 2012 | 10:47 AM
Emeraldbomber's Avatar
Default Tranny bracket doesnt line up??? FRUSTRATION!!!!!
Okay so bare with me here im frustrated and pissed off. I just bought a new motor mount, the one that bolts to the frame on the tranny side. I also bought the bracket that bolts into the transmission. I swapped the car to a manual by myself...... 30 hours of straight work
I screw the bolt into the bracket, put the bolt through the mount and bolt it on. But when I try to bolt the bracket in it doesnt line up. The far left bolt hole will bolt up fine but then the right bolt hole is up about in inch from the bolt hole!
If somebody could please help thatd be spectacular im getting tired of throwing tools at the wall. Maybe because im 17 and impatient but I need some help pleasee
Old Jun 7, 2012 | 10:52 AM
grumblemarc's Avatar
The Grumpiest
Default Re: Tranny bracket doesnt line up??? FRUSTRATION!!!!!
First things first. Car? Engine/Transmission? Mount in question?
kyden's Avatar
is this a 92-95? you need a auto to manual conversion mount.
Old Jun 7, 2012 | 10:53 AM
Red_Army's Avatar
mount it to the engine first. then mount it to the actual chasis mount.
if it still won't line up once its just the Tmount and the engine then you have the wrong one.
Old Jun 7, 2012 | 11:04 AM
s20 trans, d16z6 engine, 94 civic. I tried bolting it up the the tranny first then putting the bolt through the mounting hole but then its way off and doesnt even meet with the mount. I thought all of the brackets are the same that mount into the trans??
Old Jun 7, 2012 | 11:11 AM
The Grumpiest
So what bracket are you using?
Old Jun 7, 2012 | 12:42 PM
Id post a pic but idk how heres a link
http://www.thehondapartsstore.com/he...All&vinsrch=no
Im usuing number 8 as the mount and 10 is the bracket
Old Jun 7, 2012 | 01:58 PM
HCivExoo's Avatar
auto tranny brackets are not the same. EK's are not the same. You can't just take any tranny mount from a honda civic and expect it to fit right.
You need to have the bracket that bolts to the tranny from a 92-95 civic SOHC man. transmission. Pics would help as well.
Old Jun 7, 2012 | 08:18 PM
I bought the mount off eBay and it said 94 civic mt bracket. Maybe i was lied to. I don't know how to post pics or I would
Old Jun 8, 2012 | 03:55 AM
94EG8's Avatar
Seagull Management
How to post pics: https://honda-tech.com/forums/showthread.php?t=3032699
Also, if you didn't use an auto to manual aftermarket conversion mount for the upper transmission mount (or cut the automatic bracket/pocket mount off the frame rail and weld the manual version on) things aren't going to line up.
Old Jun 8, 2012 | 08:22 AM
I dont remember if I bought the conversion mount or not. All the rest of the mounts fit on besides the tranny bracket
Old Jun 8, 2012 | 08:28 AM
kyden's Avatar
you probably didn't buy the conversion mount then.
Old Jun 8, 2012 | 08:34 AM
94EG8's Avatar
Seagull Management
Again, post pictures. Help me help you.
Old Jun 8, 2012 | 08:41 AM
I'm on it right now in a few
Old Jun 8, 2012 | 09:13 AM
it justs keeps saying server error and says the picture cant be uploaded
Old Jun 8, 2012 | 12:07 PM
94EG8's Avatar
Seagull Management
That means either the pics or huge or there's something else wrong. Try uploading them to an image hosting site like photobucket (free) and use the IMG tags.
Old Jun 9, 2012 | 07:44 AM
I think I figured out what it is. I dont have a auto to manual conversion mount. So the engine and tranny are sitting funny right?
Maybe this could explain my leak in the axle seal where it meets with the trans?
I tried fixing the leak like 5 times
Old Jun 9, 2012 | 09:12 AM
Old Jun 9, 2012 | 09:14 AM
The Grumpiest
Old Jun 9, 2012 | 09:15 AM
94EG8's Avatar
Seagull Management
The transmission side will sit high, it will look very crooked without the conversion mount, you will have axle issues and the rear mount wont line up.
Either buy the conversion mount or drill the spot welds out of the bracket welded to the frame and weld on the manual bracket.
Old Jun 9, 2012 | 11:51 AM
delsolintegra's Avatar
Don't get upset. Auto to Manual conversions are common and with research you can find out anything. See the FAQ's section.
I give you credit for trying this at 17.
I've seen this conversion done where somebody welded a spacer on to the bottom of the auto transmission bracket to make it lower to reach the lower riding manual transmission.
If you visit some junkyards you can probably find the correct mount because they always pull the Honda engines out of the cars and the mounts are easy to access in the scrapyard.
Old Jun 9, 2012 | 12:22 PM
92lxsleeper's Avatar
the mount is not what is different. its the bracket on the passenger side frame rail.
you need a custom mount hence the "auto to manual" mount to line it up.
but between a stock auto, and a stock manual civic... the actual mount on the transmission is the same from the factory. the bracket is what is different. so the junkyard will not help you here -__-
Old Jun 9, 2012 | 12:26 PM
well poop, I thought I had finished the whole swap. Looks like ill be underneath the car for a while again. I tell ya what though, working by myself throughout this whole swap is extremely satisfying.
I know hasport and innovative make mounts for this. Any other repable companys for a cheaper price?
Old Jun 9, 2012 | 12:47 PM
http://www.ebay.com/itm/92-93-94-95-...e610bb&vxp=mtr
here you go way back in the day, this is the same mount i used when i did my first civic. it worked fine!
Old Jun 9, 2012 | 02:22 PM
il look into that, thank you
