B16 JRSC on B18c6 = Low Boost?
Old Jun 7, 2012 | 06:55 AM
JordanCivic's Avatar
Default B16 JRSC on B18c6 = Low Boost?
Hi guys
Got a complete B16 JRSC kit fitted to my B18C6 but only resulting in 2-3psi boost, i have tried to find info on the different size pulleys and the differences between the B16 and B18ITR kits without any luck, can someone provide any info? Looking to run 7-9psi.
Old Jun 8, 2012 | 12:51 AM
david974's Avatar
Default Re: B16 JRSC on B18c6 = Low Boost?
What are you crank pulley? stock Or smaller?
what is the charger pulley diameter?
Did you check for any leak?
also Does your cam timing is changed? advanced Intake?
Old Jun 8, 2012 | 01:13 AM
Stock Crank Pulley
Stock B16 supercharger pulley for 7psi ( not sure on size, will measure it )
Stock cams / cam timing. Bone stock b18c6.
Leaks? Well i dont have any idle issues, and i dont believe i have any belt slip issues, boost peaks instanatly to 2-3psi and holds to redline. Looks like a pulley config issue, but im having trouble finding further info.
Old Jun 8, 2012 | 06:32 AM
riceburner94si's Avatar
Don't know of any pulley configuration that would give that boost level. Smallest can get to my knowledge is 5-6. If you have a high idle you probably have a vacuum leak. Check all your belts again. They slip easily.
Corksil
Jan 17, 2013 09:06 PM
gosu08
Apr 27, 2009 07:49 AM
suprchrg95
May 17, 2004 01:10 PM
hypa
Feb 28, 2004 09:56 PM
