Another satisfied ITR rear sway bar/BSQ kit customer
Old Oct 14, 2002 | 09:02 AM
allenp's Avatar
Default Another satisfied ITR rear sway bar/BSQ kit customer
For all that want to get started modifying your non-TR Teg -- this is a great place. For $120 and a couple of hours, you have a significant improvement in handling. My inside-front tire is loving it! You can actually apply some throttle on corner exit without severe wheelspin.
And as far as BSQ's kit and instructions -- great stuff
The kit is very cleanly and professionally done, and the instructions (complete with color pictures) are great.
www.geocities.com/bretq
Again, I highly recommend this as a great first, easy step towards improved handling.
[Edit: Added link to BSQ's page]
[Modified by allenp, 9:04 PM 10/14/2002]
Old Oct 14, 2002 | 12:34 PM
allenp's Avatar
Default Re: Another satisfied ITR rear sway bar/BSQ kit customer (allenp)
(I hate doing this to my own posts... but...)
bump
Old Oct 14, 2002 | 12:53 PM
GSRrR's Avatar
How did u get the bolt off? Did you use a hammer and chisel or thread half a bolt-in and hit it with a hammer. I am going to do this soon and want to know the best way to do this. TIA
Old Oct 14, 2002 | 01:12 PM
allenp's Avatar
Default Re: Another satisfied ITR rear sway bar/BSQ kit customer (GSRrR)
Neither, actually. I found it easiest to stick a screwdriver through the subframe (looking from the rear of the car) at an angle such that the blade of the screwdriver was lodged in the thread of the welded nut. A couple minutes of pounding and they gave in.
Old Oct 14, 2002 | 01:21 PM
GSRrR's Avatar
Couple of minutes? I want it out the first time I hit it.
Old Oct 14, 2002 | 03:43 PM
Tweakmeister's Avatar
lol...that's why I brought out the air tools. 15seconds later...
I really do love this mod.
Old Oct 14, 2002 | 04:39 PM
Isaac's Avatar
New User
Default Re: Another satisfied ITR rear sway bar/BSQ kit customer (Tweakmeister)
Honestly, it's got to be the best bang for the buck mod ever...
Old Oct 14, 2002 | 04:59 PM
John-GSR's Avatar
Default Re: Another satisfied ITR rear sway bar/BSQ kit customer (Isaac)
cool. Thinking about it myself too. I assume that you got the USDM ITR sway bar right? was wondering if anyone else used the BSQ kit but was running the JDM ITR sway. Curious to know how 23 mm is vs. 22 mm.
Old Oct 14, 2002 | 05:18 PM
allenp's Avatar
Default Re: Another satisfied ITR rear sway bar/BSQ kit customer (John-GSR)
Yeah, it is the 22mm. When you hold the bars next to each other, it's amazing how much beefier the ITR bar is...
Honestly, I'm not sure what the spring rate difference is between 23 and 22, but I would certainly be curious to know if someone had experience.
I just can't get over how much I appreciate the difference. So worth it. The car, if not literally transformed, is significantly improved.
Old Oct 14, 2002 | 06:07 PM
JDM is a significant difference...
...in the price too
Old Oct 14, 2002 | 06:10 PM
vteg's Avatar
New User
How much is the JDM?
Old Oct 14, 2002 | 06:16 PM
GSRrR's Avatar
Default Re: Another satisfied ITR rear sway bar/BSQ kit customer (vteg)
Would the 23mm bar be overkill for a daily driver? Just wondering. I plan on getting the 22mm anyways.
Old Oct 14, 2002 | 06:20 PM
ragejed's Avatar
For the price ya. 22 is fine
Old Oct 15, 2002 | 04:56 AM
allenp's Avatar
Default Re: Another satisfied ITR rear sway bar/BSQ kit customer (ragejed)
Not sure how much the JDM 23mm bar is, but if you're looking for a significant upgrade from the 22, Saner Performance makes a 3-pos adjustable 24mm bar for around $200. Catch-22, H-T member and co-founder of the Honda-Challenge series (and class champ, I believe) swears by it.
sanerperffab.com
[Edit: Added link]
[Modified by allenp, 1:58 PM 10/15/2002]
Old Oct 24, 2002 | 10:28 AM
snkypete's Avatar
New User
will this work w/ an LS.. is there anything different from the GSR that i should know about before attempting to do this?
Old Oct 24, 2002 | 11:07 AM
Understeer's Avatar
Default Re: Another satisfied ITR rear sway bar/BSQ kit customer (huk)
Works on all models, so no problems on your LS.
I just ordered my stuff. I the kit from BSQ already, but just waiting for Acura
Carland to ship my Swaybar and parts for it.
Old Oct 29, 2002 | 08:21 PM
snkypete's Avatar
New User
Default Re: Another satisfied ITR rear sway bar/BSQ kit customer (Understeer)
thanks for the info..
btw.. anyone else having trouble accessing the link in the first post? damn geoshitties
Old Oct 29, 2002 | 08:33 PM
GSRrR's Avatar
Just try back later. Too many people been checking out Bret's site and it went over its bandwidth. I have the instructions on my computer in pdf format if you need it.
Old Oct 29, 2002 | 08:34 PM
snkypete's Avatar
New User
not more the instructions but rather the parts i have to order from acura and the kit i have to order as well
Old Oct 29, 2002 | 08:35 PM
Understeer's Avatar
I also just installed the ITR sway bar with BSQ's kit.
It took me about 2 hours to do it all. The hard part was getting the damn welded nuts off.
Other than that it was an easy install.
After driving with the bar on, I noticed a lot less body rolls, the car feels stiffer in hard cornering and more neutral steering (way less understeer)
All in all, one of my favorite mods to date.
Old Oct 29, 2002 | 08:52 PM
GSRrR's Avatar
Parts:
1.) 52300-ST7-Z01 rear swaybar ($58.30)
2.) 52315-ST7-Z01 swaybar bushing ($4.40) (2 needed)
3.) 52308-SS0-000 bushing bracket ($5.95) (2 needed)
4.) 52316-ST7-Z00 endlink bushing ($1.75) (2 needed)
5.) 52312-ST7-Z00 endlink bushing collar ($4.90) (4 needed) – this part can be reused from the stock swaybar
6.) 90175-ST7-Z00 bolt (8x35) ($2.45) (2 needed)
7.) 94050-08080 flange nut (8mm) ($0.50) (2 needed)
Note: all prices are from A&H Motorsports (prices current as of 7/1/2001)
HTH
Old Oct 29, 2002 | 09:14 PM
Volcom's Avatar
I'm also a satisfied ITR rear bar/BSQ customer. I've also helped install a 23mm JDM rear swaybar on a friends car. He is satisfied also. Not a bad mod for the two hours it took to put it on.
Aaron
Old Nov 6, 2002 | 01:04 PM
deviant1's Avatar
Default Re: Another satisfied ITR rear sway bar/BSQ kit customer (Volcom)
the BSQ kit and the BEAKS kit are two different kits right? you only need one kit correct? not both? whats the difference between these kits?
Old Nov 6, 2002 | 01:05 PM
ragejed's Avatar
Default Re: Another satisfied ITR rear sway bar/BSQ kit customer (deviant1)
BSQ, 1 side only, cheap.
Beaks, both sides, expensive, blinnng
Old Nov 6, 2002 | 05:39 PM
MachAF's Avatar
I plan on doing this soon. When I get some extra cash.
