94 Civic-steering wheel vibration+knocking sound after head gasket replaced
Old Jun 6, 2012 | 05:18 PM
Jayy11's Avatar
Default 94 Civic-steering wheel vibration+knocking sound after head gasket replaced
My friend and I just put in a new head gasket on my 1994 Civic. It was doing fine and today on the way home from work, the steering wheel started to vibrate a bit and I heard a knocking noise on the left side. When I accelerate the noise stops. When I let off the gas it starts again. When out of gear it starts again.
Could it be the lug nuts not tightened enough?
Could it be the crank pulley bolt coming loose?
Help....
Old Jun 6, 2012 | 07:19 PM
Former User's Avatar
Default Re: 94 Civic-steering wheel vibration+knocking sound after head gasket replaced
Thread titles MUST summarize the tech problem so that members browsing titles can easily understand the problem without reading the post -- Title edited.
Old Jun 6, 2012 | 10:50 PM
jbpnoman's Avatar
crank pulley coming loose wouldn't cause that. Check everything in your suspension and make sure nothing is loose there. What you're mentioning is usually caused by suspension problems.
Old Jun 8, 2012 | 05:36 AM
Jayy11's Avatar
Two of the lug nuts were loose. One was so loose I unscrewed it by hand. Noise has stopped and car is running good.
Just want more hp now. lol.
tooters bmx
Nov 13, 2017 04:38 AM
swordgsk
Dec 4, 2011 04:02 PM
Integra_RS
Apr 10, 2005 08:49 AM
Del Souless
Aug 12, 2004 10:22 PM
KillerTofu
Apr 20, 2004 04:40 AM
