What size is the Apexi N1 for the 00 Hatch?
most likely no bigger than 60mm if it's meant for a sohc honda..u may even be more unlucky and get like 57mm.. the universal one has a 60mm piping for the muffler itself and 90mm tip...but as seen from the HKS Hyper exhaust they do use 55mm piping for the sohc honda ej6 htbks..so your looking at approx 2 1/8inch to 2 1/4 inch at best unless u get crazy and get the larger turbo version N1s
APEXi N1 piping is not 2.5" diameter. It is 60mm, aprx. 2.38" diameter piping. Most of the aftermarket exhausts like GReddy, Tanabe, DC, APEXi, Skunk2/RSR use 60mm piping. I believe Thermal R&D uses 2.25"...
the only true system that can be bought is the Thermal which comes with either 2.5inch or 3inch piping.. other than that greddy does make I believe a 70mm PE2 exhaust but only for the GSR and only a few vendors carry that system in the US
https://honda-tech.com/zerothread?id=197557 link to the older info on it
he says he has it and its 2.5"
the other guy says no its 2.38
any more documented input or pictures of tape measures across cut sections?
btw: if its anything less than 2.5" i dont see what the point.
LHC
Feb 28, 2004 10:25 PM
