Universal Val Spring Compressor
Old Jun 6, 2012 | 08:52 AM
dem0nk1d's Avatar
Default Universal Val Spring Compressor
Anyone use this style of Valve Spring Compressor?
http://www.harborfreight.com/univers...sor-92900.html
if this will not work what do you guys recommend?
Old Jun 6, 2012 | 08:58 AM
Dc4LsTeG's Avatar
EK9
Default Re: Universal Val Spring Compressor
I have this one and love it, though it is pretty expensive
http://www.euroexportinc.com/store/t...ompressor.html
Old Jun 6, 2012 | 09:11 AM
dem0nk1d's Avatar
Looks great but i need something universal, and i'm rebuilding a SOHC head to pass smog with. So i was wondering if that cheap *** one will work. Doing the rebuild this weekend.
Old Jun 6, 2012 | 11:17 AM
Dc4LsTeG's Avatar
EK9
Not sure ive never used that one. But it looks easier then the ones you have to push down on it
Old Jun 6, 2012 | 11:36 AM
hondamark35's Avatar
I have a similar one to the H/F compressor you linked to that I got to use on an old push-rod motor I was working on. I didn't have much luck using it on my honda heads. There isn't much room (depending on which head of course). I use a deep-well socket and a hammer to remove them, and a rigged up, home made tool to put them back on.
Old Jun 6, 2012 | 11:43 AM
Dc4LsTeG's Avatar
EK9
Thats what I was also thinking with the h/f one, it looks wide and Im not sure if it would fit, maybe you could turn it 90 degrees and get it to work. OP if you end up buying it let us know how it works
Old Jun 6, 2012 | 12:16 PM
dem0nk1d's Avatar
what is this home made tool you talk about? the socket and hammer trick is what i use to remove the keepers. That method works like a champ. In the past i've used the huge clamp style valve compressor, on the heads with no issues at all. But now i need to get a tool for the weekend
Old Jun 6, 2012 | 12:23 PM
dem0nk1d's Avatar
if anything i return it...
Old Jun 6, 2012 | 01:10 PM
Dc4LsTeG's Avatar
EK9
Let us know if it works
Old Jun 6, 2012 | 01:25 PM
Phil M's Avatar
I've had a machine shop use the hammer and socket idea in front of me to take the valves out of this 4g63 head I brought to them. They had to get me a new set of valves because they were all bent.
Don't use the hammer and socket idea if you like your engine.
Old Jun 6, 2012 | 09:43 PM
dem0nk1d's Avatar
phil didn't you show me the hammer and socket method??? LOL! Is that eclipse head we did back in the day, out in el cajon?
Old Jun 7, 2012 | 01:42 PM
made it out of some spare brackets and pipe from work... works a lot like >this<
gucci mane
Dec 12, 2013 07:48 PM
Romo Pyro
33
Dec 26, 2009 09:13 AM
Romo Pyro
Oct 28, 2009 11:50 AM
averyvm
23
Feb 27, 2007 06:54 PM
93b16
Feb 2, 2005 04:47 AM
