Brake problem
I have a 91 si hatch and just changed the master cylinder and brake booster. The car didn't have brakes before this and still doesnt I have to pump the pedal two times for the car to slow down. I also changed the line from the master to the propotioning valve due to the nut being stripped. I bled the system twice using the passenger rear, driver front, driver rear, and passenger front method. And the car still doesn't stop. Can someone help out?
Should be able to do it using the brake pedal.
http://www.youtube.com/watch?v=m6iwrhZCdwc Then obviously you'll have to bleed the brakes again, starting with the furthest from the master cylinder.
