Failed Smog, HC(PPM), CO, NO (PPM) too high
Old Jun 5, 2012 | 10:24 AM
piggydog's Avatar
Default Failed Smog, HC(PPM), CO, NO (PPM) too high
1992 Honda Prelude 2.3si
Luckily I saved my test from two years ago
Test from 06/2010 - only thing changed after the test was on 11/2011 the distributor, and a few screws on my gas tank (also had a stock filter on in 2010, 2012 I have KN reusable cone filter)
2010 test - pass
http://i1131.photobucket.com/albums/...0smogtest2.jpg
2012 test - failed
http://i1131.photobucket.com/albums/...2smogtest2.jpg
My 2012 results are so high compared to my 2010 tests. Any ideas, the guy says my timing looks off. Do I need to advance the timing on my car? Would that only fix one of those? Should I run any fuel cleaner or seafoam in the tank, suck some seafoam through the brake booster? Thanks for advice.
Old Jun 6, 2012 | 10:20 AM
mechanix619's Avatar
Default Re: Failed Smog, HC(PPM), CO, NO (PPM) too high
2010 test - pass
2012 test - failed
Neither linked worked, at least not for me. Did you do anything that would cause your timing to be off? I wouldn't run SeaFoam on a car as old as yours, it'll most likely damage the seals. When was the last time you changed the thermostat? If the car isn't running at proper temperature it'll throw the ECU off.
Old Jun 6, 2012 | 12:33 PM
piggydog's Avatar
thx, I don't think I ran it long enough, warm enough yesterday before the test.
BenjaminJeffers
Mar 4, 2014 04:01 PM
imbest123
Mar 7, 2011 09:39 AM
ludaboy93
Mar 1, 2006 02:37 PM
crx00
Aug 6, 2003 06:37 PM
