check engine light
Old Oct 14, 2002 | 07:39 AM
laurat's Avatar
Default check engine light
cleaned engine compartment on 1995 Prelude SE 4 cyl, check engine light on. How do you reset fault code in ECM?
Old Oct 14, 2002 | 07:40 AM
Boostless97Lude
Guest
Posts: n/a
Default Re: check engine light (laurat)
disconnect the battery
Old Oct 14, 2002 | 07:44 AM
laurat's Avatar
Default Re: check engine light (Boosted97Lude)
bettery disconnected no help
Old Oct 14, 2002 | 09:47 AM
prelude1897's Avatar
How long did you keep it disconnected? Leave it off for awhile, then reconncet, and if the light comes back on, then see how many times it flashes...
Old Oct 14, 2002 | 12:16 PM
laurat's Avatar
Default Re: check engine light (prelude1897)
had both positive and negative disconnected and light come on all when driving.when restarting car light is out until drive above 2500 RPM-light never flashed
Old Oct 14, 2002 | 12:21 PM
Boostless97Lude
Guest
Posts: n/a
you have to use a paperclip and jump the codes to make the light flash
Old Oct 14, 2002 | 12:54 PM
DirtyLude's Avatar
Step 1: Check the code http://www.hondaprelude.to/main_checkengine.html
Step 2: Fix the problem
sherman
Honda S2000
13
Jun 22, 2006 04:13 PM
Corruption
Jun 3, 2006 12:08 PM
tuco_ruiz
Sep 15, 2002 05:24 PM
VTECVillain
Jan 6, 2002 11:40 AM
