Ls-v piston question
Kinda new to doing ls-vtec but i was wondering if using npr gsr style pistons would be reliable? I'd rather go oem but im getting em for 150.. Comes with pistons, rings, and pins.
Here are some pics
Here are some pics
Not a good idea if you are planning to go LS-Vtec, PR3 or P30s are the perfect pistons, and you are not going to need any modification to the rods...
I dont know about NPR, but the OEM P72 pistones, you need to machine a little bit the LS rods to make it fit...
Also this is just for a daily. Not trying to make hella power from it but I just want something faster than the ls I have now..
ahh i see. What about NPR Pr3 pistons, rings, and pins, but would it be okay to run those?
Is npr a reliable brand? I hear good things about em but not much for ls-vtec
The P72 is not going to give you as much compression as the Pr3 do also, and you are going to regret that in the future...
Go ahead and put the Pr3 or P30s
Those are the ones I`m running now, your compression with the vtec head is going to be like 12.0:1 it is fine to run with the regular gas
good to hear the pr3's working good so far.. I bought brand new npr pr3 set for my lsv ..should pick up the block from the machine shop tomorrow!..From what I've read all over online for the most part the npr pistons have held out good and proved reliable from most reviews
TurboJesse
Apr 5, 2005 03:42 PM
