OBD2B gsr swap into 93 eg si.. help appreciated
Old Jun 4, 2012 | 06:59 PM
Shut It Fool's Avatar
Default OBD2B gsr swap into 93 eg si.. help appreciated
I bought a b18c1 from a 2000 integra to put into my 93 si, and i want to use the obd2b ecu that came with the engine... what wiring harness do i use ? the stock harness or the gsr harness? do i have to wire in a 2nd o2 sensor to my ecu? do i have to do the CKF bypass trick and the VTPS trick? ive searched everywhere on different forums and everyone seems to have a different answer... no forum is about this EXACT swap so its hard to peice all the info together. I have the distributor harness jumper, alternator plug jumper and the ECU jumper harness to run the OBD2B ecu. I just need to know what else i have to wire in/change.
any help is much appreciated, thanks!!
TK_209
Oct 8, 2009 12:38 PM
SONIC BOOM
Mar 28, 2006 12:06 PM
Turbo97
Nov 18, 2005 05:53 PM
jdmeg9
May 1, 2005 08:40 AM
FAAST
Nov 9, 2004 08:06 PM
