b18c GS-R vs b18c Type-R
Old Jun 4, 2012 | 06:59 PM
Sk8NJ91's Avatar
Default b18c GS-R vs b18c Type-R
discuss please, which ones can be made faster and which one has better performance?
Old Jun 4, 2012 | 09:55 PM
3rdtimecharmer's Avatar
10 Year Member
Default Re: b18c GS-R vs b18c Type-R
Are you serious...
Old Jun 4, 2012 | 10:20 PM
mizle's Avatar
lol
Old Jun 4, 2012 | 10:59 PM
rd91sib18c5r's Avatar
R has mad vtec Yo.
Old Jun 5, 2012 | 04:20 AM
wanabebuff's Avatar
They're definitely both the same. The b18c1 (gsr) has a restricter plate in the carburetor that you can remove with an allen wrench, then if you pull that out, it is essentially the same as a b18c5 (type-r). If you want to make the c5 faster, just swap vtec solenoids off of a del sol and jb weld the IACV port closed, easy extra 25 bhp. Don't get me started on stickers and floor mats, those are the true secrets to goin' fast n *****
Old Jun 5, 2012 | 04:23 AM
Ryan96GSR's Avatar
Restrictor plate? really
is that off the throttle body?
The type R has different internals, higher compression and a different V-tec crossover.
Old Jun 5, 2012 | 06:13 AM
hbcrazy88's Avatar
"restricter plate in the CARBURETOR"...... LOL read a little bit more carefully
Old Jun 5, 2012 | 06:42 AM
Ryan96GSR's Avatar
Ya I figured as much, That's what happens when I post before I am actually awake
Old Jun 5, 2012 | 08:03 AM
wanabebuff's Avatar
hahah
Old Jun 5, 2012 | 08:50 AM
1994_Integra's Avatar
This has been discussed...A LOT...Here and on many other forums. Check out the search function
Old Jun 5, 2012 | 11:48 AM
SuzukaBlueS2K's Avatar
Factory go fast bits
Old Jun 5, 2012 | 11:52 AM
bnetkillzone's Avatar
Lol the type R has a flux capacitor in it, duh.
But no really, different bottom end and head with different internals.
No carbs, restrictor plates, or flux capacitors needed.
Old Jun 5, 2012 | 11:54 AM
beecee18's Avatar
http://www.itrsport.com/technical.html
with this all you badass's will learn something new!
Old Jun 5, 2012 | 01:18 PM
swaped89crx's Avatar
to my recollection they are essentially the same motor just some head porting is a lot better in the type-r the redline is higher due to crank weight and bearing clearances they both could use a b16 head if you'd like my true opinion.
and just don't wreck your whip doing it.
Old Jun 5, 2012 | 01:21 PM
sxysweed's Avatar
You forgot that the type argh has dual carbies.
Old Jun 5, 2012 | 03:27 PM
doood's Avatar
been there done that
you recall incorrectly
Old Jun 5, 2012 | 08:41 PM
justYncredible's Avatar
It's wU to the sOLdiEr!
can a mod close this topic please
Old Jun 7, 2012 | 12:57 AM
oh i did forget one thing the fact a true Gs-R has a dual plane intake manifold
Old Jun 7, 2012 | 04:35 PM
dragon909boi's Avatar
LOL!
Old Jun 7, 2012 | 08:23 PM
beecee18's Avatar
Is this thread nervousing you?
Old Jun 13, 2012 | 10:27 PM
long beach dc2's Avatar
Yo just be shure to cheack ur blinkers fluid and make shure ur main fuse in ur block dosent pop haha this is sad Honda tech is going down hill
Old Jun 13, 2012 | 10:32 PM
doood's Avatar
says a noob from may 2012. wtf have you contributed besides a waste of a thread?
Old Jun 14, 2012 | 02:19 PM
beecee18's Avatar
$#!T spelling and grammar,
The only thing going downhill is turds like this that bring down the honda culture with this kinda $#!T!
Looks like a five year old stepped up to the keyboard, oh wait if that was so, maybe there would be a better contribution to the thread.
Old Jun 14, 2012 | 06:24 PM
mafia's Avatar
GSR small *****, Type-R big *****.
Old Jun 14, 2012 | 06:52 PM
Fliptard's Avatar
US 00-01 B18C5 Type R is the best, has upgraded and better cams. B16a/B18 Type R have the SAME cams. GSR has it's own cams.
