DC race header
Old Jun 4, 2012 | 05:58 PM
jagumbel's Avatar
Default DC race header
i ordered a dcrh for my 03 rsx type s. will i have a CEL since there is no cat and if i do is there a way to turn it off
Old Jun 4, 2012 | 06:08 PM
doood's Avatar
been there done that
Default Re: DC race header
a defouler is hit or miss. didnt work for me so i turned it off with kpro.
Old Jun 4, 2012 | 06:24 PM
jagumbel's Avatar
kpro is my next investment so i can probably wait till then. But why does it come on? both o2 sensors still plug in right?
Old Jun 4, 2012 | 07:04 PM
prelude_h22vtec's Avatar
The CEL comes on because you are deleting your catalytic converter. The secondary 02 sensor measures cataylst efficiency.... So having zero percent cat efficiency sets off the light. The computer thinks your cat has failed, and will set a code for it. Having this code(PO420) does not affect performance, but you will fail an emissions inspection.
Don't get the race header confused with the shorty header. The shorty header doesn't delete the cat, but the performance gains aren't there.
Old Jun 4, 2012 | 07:07 PM
NHBP-TypeS's Avatar
Because the 2nd o2 is there to make sure the cat is working properly and filtering out the emissions that our car's put out. So with the cat gone, the 2nd is gonna get the same reading as the 1st o2. So the ecu them thinks that the cat is improperly working. Which should thro the code p0420 I believe. So with a defouler in place, it sets the 2nd o2 out of direct exhaust flow, which gives a different reading then the 1st o2, which tricks the ecu to thinking that the cat is properly working. I have a obx v3 RH which is the dc clone, and I get a cell from time to time with my defouler.
Old Jun 4, 2012 | 08:41 PM
jagumbel's Avatar
thanks everyone. i get a cel for one of the o2 sensors from time to time anyway so i might as well try a defouler. where can i get the best one?
(oops sorry i already found out i can get spark plug defoulers from an auto parts store) but what is the difference from the help brand 420002 and help brand 420009? i think im supposed to use the 420009 but auto stores normally stock the 420002
and prelude, i got the stainless steel race header cause i knew the shorty wouldnt make much of a diff with all the other restrictive pipes
Old Jun 5, 2012 | 07:20 AM
NHBP-TypeS's Avatar
I got mine off clubrsx for $25. I tried the 2 defoulers from autozone and bored one out to work but my CEL stayed on all the time with it. When i switched to the angled defouler from clubrsx i only get one every few months. And it seems to happen when i dont let my car warm up for a few minutes be fore driving
Old Jun 5, 2012 | 04:40 PM
yes, angled defouler from CRSX for the win.
slowB20ej8
Apr 11, 2008 07:18 PM
anto13
Jul 12, 2005 01:12 PM
VTEConly
Apr 23, 2005 02:14 PM
TrueZen
Mar 19, 2004 06:17 AM
hatch96
Oct 12, 2003 05:37 PM
